Andrew's S54 Swap
  • e30polak
    • 6136
    #106
    Nice swap!
    That torque graph looks a bit scary... :shock:
    Is your VANOS unit noisy? Do you possibly have a lazy MAF? Everything good with your fuel system?
    INSTAGRAM: @UNDR8D_EMPIRE
    • Andrew325is
      • Jan 2008
      • 1212
      #107
      Interesting. So hooking that up might make 2 of those codes disappear. I wonder if it will have an effect on the power curve.
      Plug and Play Wiring Harness Adapters for S54, S50, M54 and more.
      • FredK
        • 14764
        #108
        Well, a lack of a VSS signal in an E36 will reduce its performance. Hopefully this fixes things!
        • Andrew325is
          • Jan 2008
          • 1212
          #109
          Originally posted by e30polak
          Nice swap!
          No, the engine is quiet. The MAF is new. I haven't tested the fuel system pressure, though I don't see why it would pull 281 whp in the upper range if it had low fuel pressure.
          • Andrew325is
            • Jan 2008
            • 1212
            #110
            Originally posted by nando
            you want a VSS input. it doesn't matter if DSC is there or not. the signal comes from the DSC unit normally, but the VSS output from the E30's cluster is equivalent. it doesn't send the signal over the CAN bus, it's just a dumb signal like pretty much any older BMW.
            a generic code reader can't tell you nearly as much as BMW's software. are you using the 16 pin OBD port or did you wire up a round 20 pin? i'll have to check how mine is wired but all you really need is ground, switched 12v, and the txd pin.
            I'm using the 16 pin OBD2 port.
            • Andrew325is
              • Jan 2008
              • 1212
              #111
              Here's something else in the wiring I was unsure about. Whether or not to connect terminal 30h at the starter to X60004 #2. I connected terminal 30h to C101 #15 only. The only reason I'm asking is because the pin-out for the E46 M3 lists X60004 #2 as input from terminal 30h. However, there is no connection on the M3 wiring harness for that. Also, the ETM for the MSS54 Z3 M Coupe/Roadster lists X60004 #2 as not used, so I didn't wire it. What do you guys think?
              • nucci
                • Feb 2012
                • 11
                #112
                I was investigating that exact pin 2 nights ago so I'll share what I found:
                X276 is a body splice, though I don't know where. That same signal "S_30H" also appears at pin 3 of the X11175 connector to the A2 instrument cluster.
                I would stop using any MZ3 wiring diagram information. The DMEs are different, the EWS system is different, the DSC system is different, and all software is different. Far too many assumptions to get good information from those documents. Figure out how to use WDS. Also, figure out what date build DME you have, as that affects some pinout information.
                • nucci
                  • Feb 2012
                  • 11
                  #113
                  I am not sure where you get X60003 pin 12 from.
                  Here's a link to pinouts and block diagrams for all variants of all 5 DME plugs from WDS. It looks like the "S_30H" wire is always X60004 pin 2. Additionally, the two cluster variants here and here show "S_30H" always being X11175 pin 3.
                  • LJ851
                    • 7919
                    #114
                    ^ nucci, let me welcome you to r3v. You currently have 11 posts and have posted more helpful information than 80% of r3v could ever dream of.
                    Lorin
                    The M30 is God's engine.
                    • Andrew325is
                      • Jan 2008
                      • 1212
                      #115
                      Thanks for all the info. I was looking at the MSS54 starter section here. Anyways who knows. I'm not going to worry about it since there's no physical wire on the harness that connects to terminal 30h on the starter so who knows where that signal is actually coming from or if they just list it and its not really there. I just thought it was odd they list it.
                      • FredK
                        • 14764
                        #116
                        Is the MSS54 from a Z3M different? I have one from a Z3M and it was reflashed by the same guy. He told me that as long as it's not an MSS54HP that I'd be OK. -_-
                          • 34847
                          #117
                          Nothing wrong with the mss54hp, but yeah the hardware is the same, its just a different tune.
                          • Andrew325is
                            • Jan 2008
                            • 1212
                            #118
                            That's cool. I've been curious if they can reflash the mss70 too, but I haven't asked. Do you also have the Z3M harness? I've been curious if it reaches into the E30 cockpit better. :)
                            The only difference I know of is that there's a ground for the cruise control interface on the Z3M ECU (X60004 #35). So that's not important if you don't want that feature, but if you did and you installed the brake switch I think you'd need one from a Z3 as well because I think the Z3 brake switch gives the same signals vs. alternating signals (i.e. open/open vs. open/closed).
                              • 34847
                              #119
                              it's just a "start" input. it means it's hot when the engine is cranking, but not running. it's not going to hurt to have it hooked up, since the hardware is all physically the same, it will just ignore the input if it doesn't require it.
                                • 34847
                                #120
                                does the Z3 brake switch bolt up to the E30? that's one I've wondered about. how about the check panel?
