Metric Plug and Play S54 and S62 Wiring Adapter Harnesses from Harvey Racing
This is a sticky topic.
  • 328ijunkie
    • May 2007
    • 3961
    #136
    nice
    Check Us out on Facebook
    Full Product Line Tuning
    • cek
      • Jan 2014
      • 85
      #137
      Andrew,
      Real OEM shows two harnesses:
      - Z3M wiring harness, engine module PN 12517831637
      - Z3M wiring harness, engine ignition module PN 12517831197
      The "engine ingnition module" is a different part # than the E46 ///M3.
      Do I need both from a Z3M? or just the "engine module" one?
      (I have the full harness from the E46 S54, but it's not long enough for an E28).
      Thanks
      Vlad: '87 535is │ Maytag: '87 528e │ '88 911 │ Project Minerva - S54 E28
        • 34847
        #138
        I think you want both from the Z3. the M3 is a little shorter, although it can work.
        • GG///M3
          • Dec 2004
          • 327
          #139
          Originally posted by cek
          Andrew,
          -Z3M wiring harness, engine module PN 12517831637
          -Z3M wiring harness, engine ignition module PN 12517831197
          Thanks
          You should be able to run it into the cabin. I did that with my e36
          • Andrew325is
            • Jan 2008
            • 1212
            #140
            The E46 M3 ignition coil harness is quite a bit longer than the Z3 version because the ECU is mounted on the left side of the engine bay on the E46 as opposed to the right side on the Z3. That's opposed to how it is with the main harness module which have wires that exit on the left side of the engine, so that section of the Z3 harness is longer to reach the right side of the engine bay. So you only really need the main harness module for the Z3, and the other 2 sections for the E46 M3.
            Plug and Play Wiring Harness Adapters for S54, S50, M54 and more.
            • Andrew325is
              • Jan 2008
              • 1212
              #141
              I've became aware of a potential issue with using the E34 M50 oil level sensor on S54, M54, and M52TU engines, so I recommend not installing that. So from now on I am omitting that connector on S54, M54, and M52TU adapter harnesses for E30 and E28 that have check control. The engine's original thermal oil level sensor should remain installed. The thermal oil level sensor includes an oil temperature sensor that the DME uses to monitor oil temperature. According to BMW, "The engine oil temperature is required for VANOS activation. It provides a more accurate indication of the engine temperature than the engine coolant temperature." So without the thermal oil level sensor installed VANOS may not function properly.
              The adapters for older engines such as S50 will still include the E34 M50 oil level sensor connector if your model has check control.
              • diesekte
                • Sep 2013
                • 417
                #142
                Also, as I found through trial and error (luckily cheaply), if you have the arc asylum pan, the E34 sender will not fit
                • frantic
                  • Mar 2008
                  • 62
                  #143
                  Does the original thermal sensor fit in the E34 pan? I've still got my pan so will have to have a look next oil change.
                  • Andrew325is
                    • Jan 2008
                    • 1212
                    #144
                    It should. It seems to only fit one way though, so rotate it until the holes match up with the studs.
                    • Andrew325is
                      • Jan 2008
                      • 1212
                      #145
                      I've just confirmed that the S54 oil level sensor is a direct plug and play with the E34 M50 oil pan. :)
                      • Brian D
                        • Mar 2006
                        • 832
                        #146
                        Originally posted by jrods
                        Andrew i would like to ask you what are my options as far swaping
                        an s54 into a e34 535i 1992. I know that this is not a common swap
                        but that is the way i want to go. what could be done with wiring
                        harness and ecu on both cars.
                        Thank you for your help
                        J rod
                        Originally posted by Andrew325is
                        I can make a wiring harness adapter for you. The E34 wiring is like the E36. You need to use the stock S54 wiring harness and ECU.
                        Pardon me for being painfully dense, but this means that you could do an M54 into a 1993 535 (m30) also, correct? If so, I think I've just decided what to do to future proof the old girl...
                        I would want to get the wiring harness, dme, throttle pedal from the donor I assume? Anything else that I should add to that list?
                        Thanks guys, this is a really great thread.
                        1973 Bavaria
                        • Andrew325is
                          • Jan 2008
                          • 1212
                          #147
                          Yes, I can make an M54 adapter harness for the 535i. That would be an awesome choice for that car!
                          Take the whole cooling system with rad & expansion tank too, & gearbox if its manual. For most everything else use the E34 M50 stuff as you probably already know, and of course get the E38 728i oil pickup tube (the correct one for your engine build date).
                          • Masterchoans1
                            • Jan 2016
                            • 2
                            #148
                            this is awesome. Literally just made an account to get my hands on an s54 e36 swap harness. Just gotta get my post count up so i can pm you
                            • Andrew325is
                              • Jan 2008
                              • 1212
                              #149
                              Email me at eurotrash8@gmail.com.
                              • Masterchoans1
                                • Jan 2016
                                • 2
                                #150
                                Email sent. Let me know if you got it, I sent it through the forum, before i saw your post.
