M54 dual vanos engine wiring information thread
  • DesertBMW
    • Aug 2011
    • 1040
    Refer to this thread for all future information:
  • hoveringuy
    • Dec 2005
    • 2743
    Good stuff! How do you like that motor in the car?
    • DesertBMW
      • Aug 2011
      • 1040
      It is only 2.5L but you can feel the flat steady torq do to the disa system. Engine is perfect for E30 chassis for sure
      • Andrew325is
        • Jan 2008
        • 1212
        Okay this is awesome. You rock! I want to put an M54 in something soon. :)
        Plug and Play Wiring Harness Adapters for S54, S50, M54 and more.
          • 34844
          I need to crack open an MS43/45. These seem like a natural replacement for the aging M50/M52.
          • 95///M3
            • Mar 2005
            • 181
            Great work, again.
            • hoveringuy
              • Dec 2005
              • 2743
              Here's what it looks like in an e30 (with an OBD1 harness):
              • woutnieuw93
                • Mar 2015
                • 3
                Can you please re-upload the images? I need them for my swap.
                • woutnieuw93
                  • Mar 2015
                  • 3
                  Since mister DesertBMW decided to remove the info and would only supply the info if I bought his services for programming the EWS, i am posting his post again for anyone who is struggeling or needs the info.
                  Assuming you bought some good 99-04 dual vanos engine with complete
                  harness and ecu with relay tray, and want to do a swap into your E30, you will also need X60004 harness plug that goes from the DME to chassis of donor car, the rest of the wiring is pretty much integrated with the engine. You will also need electronic gas pedal with electrical plug from donor car if you have MS43 dme engine. And that’s about it. The rest of the components is pretty much the same as doing M50 swap. This thread will focus on wiring and engine management system only.
                  Your engine harness will have few connectors that plug into chassis and those are:
                  4 pin connector:
                  1: empty
                  2: switched 12+ from ignition switch (red/white wire) this turns on DME relay
                  3: reverse light switch on transmission (yellow/blue wire)
                  4: reverse light switch on transmission (white/green wire)
                  8 pin connector:
                  1: starter run wire from ignition switch (black wire)
                  2: oil level sensor switched 12+ from ignition switch (brown/green wire)
                  3 4 5 6 7 8 are all empty
                  The dual 2 pin connectors with red wires are all 12+ constant battery
                  You will have to wire fuel pump relay the same way it is on E36, it is just basic 5 pin light green relay. The DME and Injectors relay is already integrated into MS42/MS43 harness.
                  40 pin X60004 plug wiring:
                  1: alternator charge indicator signal, [run this wire to inctrument cluster battery light]
                  7: ground wire for electronic pedal to pin 1 [MS43 only]
                  8: electronic pedal signal to pin 4 [MS43]
                  9: voltage supply for pedal pin 5 [MS43]
                  10: fuel pump relay activation ground wire [wire this to fuel pump relay, sends ground signal to activate fuel pump relay coil]
                  11: oil pressure warning light [wire to instrument cluster oil pressure light]
                  12: ground pedal sensor to pin 2 [MS43]
                  13: signal pedal sensor to pin 6 [MS43]
                  14: voltage supply for pedal to pin 3 [MS43]
                  17: RPM signal to instrument cluster
                  26: switched +12 from ignition switch
                  32: K-line to pin 7 of OBD2 connector
                  That is it for X60004 connector, no need to connect any other wires
                  Engine temperature sensor will have to be wired independently and installed somewhere on the cooling system.
                  There will also be a ground wire brown color that you must bolt to the chassis ground. Also fat wire from starter needs to go to battery 12+, also don’t forget to run one power wire from battery + outlet to the fuse box.
                  DME location can be left there to sit on top of the fuse box but it does not look pretty. 99-00 MS42 engines will work with E34 throttle cable but the end of it needs to be shaped into a ball to fit the throttle linkage. It is still electronic throttle, cable only operates two wish sensors inside the body. So MS42 and MS43 and almost the same, and M52TU and M54 is basically the same engine. You will need exhaust manifolds from 96-99 E36 as well as the engine mounting brackets, E46 stuff does not fit, it is too big. There is a fuel tank vent hose that plugs in the back of the manifold, that needs to be plugged, then you just run the fuel tank vent line to recirculating valve that is located behind oil filter housing
                  I am not running heater lines on my engine, but if you have to, the rear one will plug in just fine, you have the install a T on the front outlet then run it back to the heater and the other side of the T to the radiator bottle. AC compressor will have to be triggered manually the same way it is with M50 swaps. Thermostat outlet lines, just cut the clamps and remove quick connects from the E46 hoses and plug them on the thermostat housing then cut to fit E36 radiator hoses, hoses must be Gates brand. Remote fuel pressure regulator must be installed, 96+ E36 one also works and that’s what I am using.
                  That’s about it, the rest is the same as if you were doing M50 swap.
                  Donor E46:
                  I am also using E46 power steering lines without cooler. As you can see in the photo dual vanos engine package installed, and you see the plastic DME holder with relays, that’s how you should get your engine, if you get it with harness all cut up then it may be a problem getting the right harness.
                  You can see here the S52/M52 exhaust manifolds with 02 sensors installed, then the lines wired to the block so that they don’t touch the manifolds. Rear 02 sensors are not required with my programming.
                  Testing and experimenting:
                  Video of engine running smooth:
                  List of components removed with my programming:
                  EWS system
                  Rear oxygen sensors
                  Catalytic converter monitoring
                  Secondary air pump system, pump relay and monitoring
                  Fuel tank pressure monitoring and module
                  DSC ASC EGS CAN bus communications
                  Vehicle speed sensor
                  Radiator temperature sensor, and fan module
                  Clutch switch, brake switch, cruise control MFL steering wheel
                  Steering angle sensor
                  And few more that I can’t remember now, but it all runs great and there are no codes. You won’t be able to have check engine light feature with MS42/MS43
                  • DesertBMW
                    • Aug 2011
                    • 1040
                    Information is wrong and confusing, that is for E46 harness that does not fit E30 chassis. This is why I erased that one and updated the other one because you must use E39 harness.
