E30 S54 Swap AC signal input to DME
  • R3Z3N
    • Jan 2011
    • 3056
    #151
    CEL is triggered via CAN, so you need to wire up the CAN adapter.
    • Staszek
      • 2533
      #152
      Thanks!
      • R3Z3N
        • Jan 2011
        • 3056
        #153
        For future reference on the Gen 1 board here is a complete wiring so that the DME controls the aux fan fully based on Temp, A/C pressure, Speed etc:\
        • R3Z3N
          • Jan 2011
          • 3056
          #154
          And for Gen 2:
          • Andrew325is
            • Jan 2008
            • 1200
            #155
            I sold one of Garry's CAN controllers to someone who hasn't been able to get the A/C compressor to turn on. He says he has everything connected properly and Garry has even replaced the CAN controller for him and it's still not working for him. He says he's receiving the following error: "DME signal error CAN bus instrument cluster"
            I'm not sure exactly how the controller functions. I just do the wiring and offer the controller as a courtesy with my harnesses. Does anyone have any ideas as to what the issue could be? His car is a 1999 M3 with an M54 swap.
            Plug and Play Wiring Harness Adapters for S54, S50, M54 and more.
            • gpeterson
              • Aug 2012
              • 119
              #156
              That error doesn't mean anything other than his swap flash didn't suppress it. The CAN board doesn't emulate all cluster messages because it doesn't need to and some need a partial VIN.
              He is in touch with me to sort things out.
              • R3Z3N
                • Jan 2011
                • 3056
                #157
                ... He says he's receiving the following error: "DME signal error CAN bus instrument cluster"...
                FYI, the files I gave you have a subcategory in the DTC XDFs for DTCs to suppress, so that you can do that with your EWS delete. I am willing to walk through the usage with you remotely.
                • gpeterson
                  • Aug 2012
                  • 119
                  #158
                  Did you intend to quote someone else? I didn't do his swap flash.
                  • Andrew325is
                    • Jan 2008
                    • 1200
                    #159
                    Awesome thanks! I didn’t do his swap flash either.
                    • Afzil
                      • May 2020
                      • 1
                      #160
                      hi, how does one go about purchasing one of these units
                      • RBrom84
                        • May 2020
                        • 2
                        #161
                        Does anyone have the wiring diagram/ pinout for the gen 2 module e36 with s54 ecu? thanks.
                        • R3Z3N
                          • Jan 2011
                          • 3056
                          #162
                          This is for e30 but the only difference is pin 3, 10, 12 and 13
                          • RBrom84
                            • May 2020
                            • 2
                            #163
                            Thanks for the quick response, I need to know which wire is the e36 switched negative from the evap /pressure switch on the gen 2 board?
                            On the gen 1 board 4 is positive e30 style and pin 7 is negative e36.
                            • JVaz11
                              • Nov 2017
                              • 6
                              #164
                              Hello guys,
                              how can I get one of this controllers ?
                              thanks
                              Johnny
                              • JVaz11
                                • Nov 2017
                                • 6
                                #165
                                Hello
                                anyone?
