Z3M/E39M5 Accelerator pedal potentiometer?
  • Loupoz
    • Feb 2012
    • 166
    Anyone ever tried taking one of those and fitting it in an E30? Part# 13621407446. For the purpose of not replacing the original accelerator pedal.
    A 324td uses a similar setup, maybe one could source parts from one to make it happen, of just fab something up.
    My 325I Mtech1 S54 Build
  • whodwho
    • Jun 2008
    • 1547
    I have one I am playing with but haven't fitted to the car yet, I might try to take a few minutes to see what I can do with it this weekend
    My M20 Frankenbuild(s)
    4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
    • whodwho
      • Jun 2008
      • 1547
      Here was someones else's idea and seems like it would work ok
        • 34844
        you could probably make it work, but check out the parts prices. it will cost you at least 3-4x as much as it would to use a regular DBW pedal from an E46.
        • DesertBMW
          • Aug 2011
          • 1042
          Problem here is that sensor is exposed to the hot engine bay as well as some possible moisture coming from the front during rain driving.
          [/QUOTE]
            • 34844
            Why would you do that.. It's meant to be mounted to the pedal linkage inside the car, not the end of a cable. lol.
            • Jb325is
              • 2137
              I don't think it's a bad option if you figure out a way to mount it inside the car. There isn't a great way to fit the e46 pedal inside the car, and failures are too common IMO... The Z3M/e39 piece may be prone to fail as well though, I don't know anything about it. I like DBW, but I do not like the pedal
              - '88 m54 coupe
              <3
                • 34844
                I think you can make it work pretty well, but it's just expensive. You'd need all the linkage and stuff from a Z3 or E39. Probably would take a little welding, but nothing crazy.
                Can't you weld the clips onto the floorboard for the E46 pedal? what about the E90 pedal? I think they are electrically the same, but have been wondering. They might be easier to mount, dunno..
                • moatilliatta
                  • 6158
                  Anyone have photos of this completed?
                  @Zakspeed_US
                  • moetilliatter
                    • Jun 2022
                    • 1
                    I'm also looking forward to his cool "test"bob the robber
                    • moatilliatta
                      • 6158
                      Bizzaro World.
                      @Zakspeed_US
