Help wiring oil temp gauge to S54
  • Staszek
    • 2533
    I am in the final stretch of my swap. One thing I cant figure out is how to get my oil temp gauge to work. I am assuming that the S54 has an oil temp sensor somewhere.
    My gauge cluster was restored by Bavarian Restorations, he built in a stealth oil temp gauge that is a digital readout in the cluster. Off the back of the cluster, there is one wire that goes to the oil temp sensor.
    How do I wire that?
  • R3Z3N
    • Jan 2011
    • 3056
    Note: pictures are clickable to sale links
    You will use one of the ports on the S54 oil filter housing (I have oil temp and pressure so I have this:
    You will have the stock temp sensor going to the ecu, and another just for the guage.
    You then add a temp sensor such as this:
    From there wire power and ground to the addition that Bavrest added, and signal from the temp sensor.
    I used these connector behind the cluster: Hilitchi Connectors
    I believe the gauge that Bavrest uses will read 104 at it's lowest mind you. So if you just started your car even in freezing weather, 104ยบ will be the readout.
    • Staszek
      • 2533
      Exactly what I needed thanks! I was always wondering why you couldnt just tap the singal from the S54 thats already there. I am assuming because it doesnt transmit the same way.
        • 34839
        Because the S54 oil temp sensor is built into the oil level sensor, and it's only sent to the cluster via CAN.
        • Staszek
          • 2533
          Hmm I am wondering of G Peterson Can Bus can send it?
          • R3Z3N
            • Jan 2011
            • 3056
            His documentation states they are digital, not analog outputs, which in the controllers case I believe only means sink to ground. Check with him and post back here. You would of course need to know the voltage sweep of the sensor and best to know the curve as well.
            • BeirBrennerE30
              • 2740
              Likely no. But you can make your own box to read the CANbus. Arbid. 0x545 byte 4 on the primary CANbus and Arbid. 0x720 byte 3 on the secondary CANbus are the oil temp read from the oil level sender. It is in deg C and is calculated with ((hex -> dec) -48). Then send that to your gauge in whatever form its looking for.
              e30sport.net
              '89 325is - m20b25 - 5-speed - Individualโ€‹
              '06 M3 Competition - 6-speed
              '97 Range Rover Vitesse
              • Staszek
                • 2533
                Eh sounds complicated lol
                Im going with R3Z3N's solution.
                  • 34839
                  The sensor doesn't send a voltage signal like a regular sensor - it's processed by the DME and sent to the cluster as the temperature. You're better off just getting a regular analog sensor and putting it in the engine somewhere.
                  • dude8383
                    • Jan 2005
                    • 10387
                    https://www.bimmerworld.com/Oil_Distribution_Block_WM.jpg
                    https://www.jegs.com/images/photos/600/635/635-63-220.jpg
                    Yup, I have the podi gauge and I'm utilizing this exact distribution block so that I can get oil temp among other things.
                    • Staszek
                      • 2533
                      Thanks looks like a clean solution.
                      • terraphantm
                        • Apr 2016
                        • 20
                        It might not do so right now, but I can't imagine it would be particularly difficult for him to add the capability to his software.
                        • R3Z3N
                          • Jan 2011
                          • 3056
                          So this is how I did it on mine:
                          • Staszek
                            • 2533
                            Hey Justin,
                            Did you get a check engine light from using two sensors? I am throwing a code.
                            • R3Z3N
                              • Jan 2011
                              • 3056
                              ^My additions have nothing to do with the ECU, nor technically the Guage Cluster (except for the voltmeter).
                              Which code do you get? My guess lower rad temp sensor? If that is the case, weld in the bung and wire it to the ECU, or code it out.
