S54 making the jump
  • rs4pro3
    • 5808
    #61
    Originally posted by Jean
    rs4pro3 - baller!
    If I just had the other half :(
    85 325e 2.7 ITB'd stroker
    • e30polak
      • 6136
      #62
      Originally posted by hoveringuy
      Who is running an M52 with factory ecu here?
      I'm not talking about a standalone system or a race motor. I would only be interested in the M54 if I could run it with the factory ecu. Maybe I'll get frustrated enough and design/build an emissions emulator.
      Find the Polish guy on here who did the swap. He should be able to help you out. Plus with the m54's small intake manifolds, you can get a bigger brake booster along with bigger brakes. :D
      INSTAGRAM: @UNDR8D_EMPIRE
      • blueapplesoda
        • Dec 2005
        • 1904
        #63
        Ive been thinking heavily about this swap too....
        Whats with everyones "just do an euro s50 swap" bullshit? I want an s54 damnit not an s50us or s50b32.
        If Vanos is not a problem, solved by just by-passing it, then I think this swap truly shouldn't be a problem. Any sort of capable EMS can run a motor without vanos.
        • hoveringuy
          • Dec 2005
          • 2749
          #64
          The only reason I would want an M54/S54 over an S52 is because of the dual VANOS (and the aluminum block on the M54). Why does everyone keep talking about locking out the VANOS with standalone?
          I want to run the stock ecu and keep the VANOS.
          The M50 was a big mystery until everyone put some effort into learning it and making it work in the e30.
          The M54 is the next generation and I'm sure we can tackle adapting it into the e30 without standalone management.
          Is it too early to talk about N52?
          • PiercedE30
            • Apr 2005
            • 4220
            #65
            Why get rid of the Vanos when the Pectel unit can actually control both vanos units properly?
            My 2.9L Build!
            • deutschman
              • May 2008
              • 5958
              #66
              Originally posted by BeirBrennerE30
              as a rule... if you have to ask how to do it then you shouldn't try
              thats the worst way of looking at things ever! if people thought like that then no one would ever do anything amazing! there are so many things that have been done for the first time and no one knew how to do it right. they just dug in their heals and went for it.
              the right way to look at it is. do i have enough $? then if the answer is yeas, you go for it and all the problems you run into along the way will work themselves out. with some $ time and a lot of patients you can do anything.
              • Ray McCooney
                • Jun 2006
                • 1088
                #67
                I believe you may have missed the intent behind Beir's commentary. A truly industrious/enterprising individual will go forth and actually try to achieve his or her goals without consulting the bench racing community on how best to approach it.
                Other people in this thread seem to understand this much.
                • E30Kaiser
                  • Mar 2008
                  • 1790
                  #68
                  As I have heard before the S54 is just now being used with (modded)stock ecu by Bimmerworld as a swap. Will try and figure out more information once they get back from their race this week.
                  "We're not here for a long time, we're here for a good time"-Colin McCrae
                  • kristov
                    • 222
                    #69
                    So, today my stock S54 managed 305 rwhp and 317 rwnm with Autronic SM4 and locked cams. Compared to stock dynographs with VANOS you loose some torque below 4000 rpm - but as the E30 is a lighter car I don't think it will make a big difference in overall performance.
                    • Lag
                      • Jul 2008
                      • 358
                      #70
                      Awesome!! Congrats I am glad to hear that it went well for you!
                      • hoveringuy
                        • Dec 2005
                        • 2749
                        #71
                        Congrats on the S54! Sounds like a fun project.
                        You have locked cams, which brings up a question I have. How are the cams mapped in the stock ecu? Are they mapped strictly as phase-rpm or are there more variables involved phase-rpm,throttle position, etc.
                        Can the cams be timed by a standalone cam position controller??
                        • etxxz
                          • Feb 2006
                          • 2085
                          #72
                          pics?!
                          No more e30s for me.
                          88 black BMW OBDII 332is dedicated track [sold]
                          88 BMW OBDII bronzit 332is [RIP 03/08]
                          91 BMW 325i [sold]
                          86 Corolla 'Ae86' HB 20v trd [sold]
                          http://youtube.com/watch?v=pTj7Hn9v5Rs
                          • matt
                            • 3732
                            #73
                            In an M50/S50 with vanos, the position of the vanos is based on RPM and load (mass flow) and coolant temp.
                            With an S54 it's much more complicated on every level as it has maps for each cam's position based on a number of factors.
                            • ForceBangBlow
                              • Jun 2008
                              • 61
                              #74
                              sick!
                              Jake Rawson - Media blasting * Powder coating * Fabrication * Service * Repair
                              • madjurgen
                                • May 2005
                                • 1203
                                #75
                                Update. Hard to understand but you can get the jist of it.
                                "In Regard Bimmerworld, i called james yeasterday and i spoke to him regarding the kit and he say's that they have it ( i mean if you got the stock S54 DME just send it to them they will modifie it and will remove the EWS , and they have a wiring to fit on E36 but you have to do the cluster which they will send a guid for that) so they can run oure E36 S54 but in that with $3100 "
                                As time went on, the factory developed the car each year, making it faster, more comfortable, and capable of handling at higher speeds.
                                You don’t want this. You want the trickiest, most dangerous, oldest model you can find. Only then can you prove to the world that you’re a man.
