N52 Swap Discussion
  • hoveringuy
    • Dec 2005
    • 2752
    #421
    Are you sure your exhaust won't clear? I checked mine and it's fine. In fact, there's a perfect recess seemingly exactly for the #2 runner.
    Maybe it's because I have a facelift car?
    • hoveringuy
      • Dec 2005
      • 2752
      #422
      Exhaust update. My headers are almost done, just need to weld the 3-bolt flanges on when I get the secondary done.
      No V-bands for me, at least not here. I've always felt that the OBD2 flanges were super-easy to remove and install. V-bands can be king\d of a wrestling match when I've needed to line-up 2 at once.
      The reducer isn't just a cone, but has an S-shape. These were fully back-purged, the only place I got sugaring was my tacks.
      Click image for larger version  Name:	ex1.JPG Views:	0 Size:	72.7 KB ID:	9964865 Click image for larger version  Name:	ex5.JPG Views:	0 Size:	55.3 KB ID:	9964866 Click image for larger version  Name:	ex4.JPG Views:	0 Size:	71.5 KB ID:	9964867 Click image for larger version  Name:	ex3.JPG Views:	0 Size:	68.0 KB ID:	9964868 Click image for larger version  Name:	ex6.JPG Views:	0 Size:	68.4 KB ID:	9964869
      • Habla
        • May 2004
        • 1470
        #423
        *snip*
        It looks well done by some PO, but not factory? My 91 318is doesnt have this notch. Anyone else?
        Absolutely loving the progress on this, you guys. Its the perfect motor for a 318is :)
        Peter
        -Peter
        318is slicktop | F15 35dM | F250 SD
        • hoveringuy
          • Dec 2005
          • 2752
          #424
          Peter
          I'll fess-up. I did it.
          • hubcapboy
            • Oct 2017
            • 292
            #425
            That's weird, hoveringuy , you're awfully quiet over there.
            • hoveringuy
              • Dec 2005
              • 2752
              #426
              Yes, I ran out of things to do with the engine hanging from my rafters so I took an hour to install it. Super easy.
              The headers clear everything just fine and I probably would have had 1/4" of clearance between #2 and the frame rail even without the relief, but it sure looks cool. I went with 3-bolt flanges instead of V-band and those are nicely accessible. Miles of clearance to the CAB, subframe and sway bar, like OEM.
              Click image for larger version  Name:	Capture.JPG Views:	0 Size:	67.9 KB ID:	9967215 Click image for larger version  Name:	Capture2.JPG Views:	0 Size:	70.6 KB ID:	9967218 Click image for larger version  Name:	Capture3JPG.JPG Views:	0 Size:	75.8 KB ID:	9967216 Click image for larger version  Name:	Capture4.JPG Views:	0 Size:	52.0 KB ID:	9967217
              • hoveringuy
                • Dec 2005
                • 2752
                #427
                It all fits.
                The oil pan is very svelte and is equal in height to the subframe, plus with the bevel it probably has more clearance than an original M20. Plus, being fabricated from 14Ga steel it can probably do double-duty as a skid plate.
                The shifter is nicely centered, like it was engineered to be that way.
                The engine is centered in the bay and lines-up longitudinally with the center of the car.
ID:	9967220 Click image for larger version
ID:	9967221 Click image for larger version
ID:	9967223 Click image for larger version
                • hoveringuy
                  • Dec 2005
                  • 2752
                  #428
                  The driveshaft isn't actually fabricated yet, this is a dramatic re-enactment to show how it will look. I cut it to the correct length and dropped it at Drivelines NW hoping they could just weld my yoke onto the e30 shaft but they said it was non-serviceable, I'm having a completely new shaft fabricated. I believe an M3 automatic front section would have fit, however.
                  These photos also show the difference in how the GS6-17 transmission found in the 328i fits differently than the longer GS6-37. I have the exact same mounting tabs as a G260 and was able to re-use all of my stock mounting hardware. Nice!
                  X3 booster has miles of room.
                  I did get the motor to start!
                  Many thanks to Nando for coding the ECU and providing technical assistance. My MSV70 is coded as a 2007 Z4.
                  It took exactly 3 wires on the ECU external to the motor to get it to start. Battery, Ground, and the wake-up (IGN) wire. That's it!
                  I jumpered the fuel pump on and manually energized the starter solenoid. It starts and runs. (loudly, as my neighbor pointed-out..).
                  After I got it running I wired-in my EKP fuel relay and had an issue with the fuel pump coming on with IGN and staying on. Nando pointed-out that the EKP fail-safe when it doesn't have communications with the ECU is that the pump stays on.
                  So, even though I had an EKP and the connectors from an X3 which was clearly labeled as a "CAN 11h" protocol unit, there's a difference in how the CAN lines are terminated in the X3 versus the Z4. Remember the ECU thinks it's in a Z4....?
                  The X3 EKP plugs are missing the jumper loop between pins 8 and 15 and once I added that loop it works great. Pictured is @hubcapboy's Z4 EKP plug.
                  If I apply wake-up power to the EKP without power to the ECU, the pump will run and stay on. As soon as I apply wake-up power to the ECU the pump shuts off until the ECU senses engine rotation and then the pump comes on again. Sweet.
                  To do: I need to finish fabbing the exhaust now that I can work with the motor in the chassis and figure-out the cooling system.
                  Click image for larger version  Name:	Capture.JPG Views:	0 Size:	74.2 KB ID:	9967227 blah
                  Click image for larger version  Name:	Capture2.JPG Views:	0 Size:	70.9 KB ID:	9967228 Click image for larger version  Name:	Capture3.JPG Views:	0 Size:	84.7 KB ID:	9967229
                  • hoveringuy
                    • Dec 2005
                    • 2752
                    #429
                    One other thing that has been absolutely priceless is the OBD2 port.
                    The Z4 uses K-line bus communications and the E90 that my harness came from doesn't, so I had one missing wire in the harness to make it work. The #2 pin next to the wake-up signal on #1 needed to be added, that's the K-line signal. Once that was done there were only 3 wires to my OBD2 port: K-line, power and ground.
                    It's been incredibly useful, because when the engine doesn't start, and you have 6 codes, one for each individual injector being open-circuit, it's a great tip-off that you should probably plug the injector harness in....
                    I'm working on getting INPA so I can go deeper.
                    Click image for larger version  Name:	Capture.JPG Views:	0 Size:	79.8 KB ID:	9967247
                    Click image for larger version  Name:	Capture.JPG Views:	0 Size:	71.6 KB ID:	9967248
                    • wazzu70
                      • Jan 2005
                      • 1143
                      #430
                      Great update! All these N52 projects are inspiring and its nice to see the solutions available. With Nandos ECU coding it makes it really easy to do this swap without a standalone which is awesome.
                      -Nick
                      M42 on VEMS
                      • hoveringuy
                        • Dec 2005
                        • 2752
                        #431
                        My task an purpose this week has been to complete the cooling system and get enough of the exhaust done so that I could let the car idle.
                        The first challenge was the hose from the radiator to the thermostat inlet. It's tight, and the hose was initially riding on the radiator with a kink in the bend.
                        Fortunately, the thermostat is bolted to the water pump and can easily be moved back so I did that. An aluminum adapter plate, the holes are 25mm on-center and I moved them at a 30degree angle for 30mm. The math inclined will calculate that it results in an extra 15mm of clearance.
                        Lots of clearance everywhere now. Sorted.
                        Click image for larger version  Name:	Capture2.JPG Views:	0 Size:	73.4 KB ID:	9968420 Click image for larger version  Name:	Capture3.JPG Views:	0 Size:	74.2 KB ID:	9968419 Click image for larger version  Name:	Capture.JPG Views:	0 Size:	74.0 KB ID:	9968421
                        Click image for larger version  Name:	Img_2021_01_08_18_29_09.jpeg Views:	0 Size:	76.5 KB ID:	9968440
                        • hoveringuy
                          • Dec 2005
                          • 2752
                          #432
                          The lower radiator hose ended up being a Gates 21887 hose matched with the 90 degree fitting that normally connects to the E90 radiator, except it now connects to the thermostat. The indexing tabs on the thermostat need to be removed so that the 90 can rotate.
                          There are two versions of the 90; some have the fitting for the radiator outlet temperature sensor, which is used by the DME to control the aux fan. I use the e30 dual-temperature switch in the stock radiator, so no temp sensor here.
                          What does the Gates 21887 normally fit? It's the lower radiator hose for an E30 with M20. A sign from the Gods! *Update* The M20 upper radiator hose, Gates 21886, actually has a tighter 90 and can be cut to fit. Both work, I think the 21886 works better.
                          Click image for larger version  Name:	Capture.JPG Views:	0 Size:	74.4 KB ID:	9968450
                          The sharp-eyed may have seen the cross-under tube in the post above and thought I grabbed some conduit I had laying around to fabricate my cooling system. Nothing could be further from the truth, it wasn't laying around- I had to go out and buy it.
                          it's a prototype to see how it works, the final one will be some kind of bent 7/8 stainless pipe. It replaces the plastic piece found on E90's that won't fit the E30. It's meant to connect both the cooling reservoir* and heater core return to the thermostat.
                          Works just fine so far. Routing is tidy. Next...
                          Click image for larger version  Name:	Capture2.JPG Views:	0 Size:	73.4 KB ID:	9968449
                          * I'm running the stock e30 reservoir, but there's no reason that it couldn't be on the passenger side. The cross-over would still be needed for heater core return.
                          • hoveringuy
                            • Dec 2005
                            • 2752
                            #433
                            There are two versions of the thermostat. The X5 and most others. They both work fine, but the X5 one (left) has a 90 in the outlet that results in more direct and cleaner hose routing.
                            Click image for larger version  Name:	Capture.JPG Views:	0 Size:	77.1 KB ID:	9968455
                            The upper hose is presently a 45 degree fitting and an E30 upper hose. Not difficult.
                            Missing from this picture are two things 1) the e30 cluster temp sender and 2) a 3/4 nipple on the hose that feeds the heater core.
                            My plan is to use an M54 straight fitting with the temp sender taken off the lower radiator hose of an M54. That's where the e30 temp sender will live in place of the 45 fitting.
                            There are off-the-shelf radiator hose adapters that that will give me the 3/4 hose fitting, but I plan to fabricate a stainless 90 at the rad inlet that will allow a tighter 90 required to have the straight fitting on the engine, and that will have the 3/4 hose drop straight down next to the radiator end cap.
                            Click image for larger version  Name:	Capture2.JPG Views:	0 Size:	75.4 KB ID:	9968454
                            Purging the cooling system. You just let the electric coolant pump run for a few minutes and you're done. Neat-O!
                            Click image for larger version  Name:	Capture3.JPG Views:	0 Size:	112.1 KB ID:	9968456
                            • hoveringuy
                              • Dec 2005
                              • 2752
                              #434
                              Finally, here's what my exhaust looks like. 2" secondaries into a Burns merge, 2" to 2.75". Why 2.75"? Because 2.5" is too small and 3" is too big....
                              • hubcapboy
                                • Oct 2017
                                • 292
                                #435
                                This is outstanding work.
