iX wheel thread
2 x 88 IXs, 91 318IS, 90, 97, 98, 01 M3s, 95 540I 6spd,
Current project 91 318is build thread
http://www.r3vlimited.com/board/showthread.php?t=385094
Originally posted by AWDBOB View PostHey, you've got good taste ;)
Very similar just a little different spacing and pattern89' 325ix Diamantschwarz/Black rattle can...
Insta: r_moose_w
Originally posted by flyboyxI imagine her smelling like spoiled milk and having a half inch crust of doodoo circumnavigating her butthole.
nando would a 17x8 +25 with a 214x40 work or will that still be to low offset? Running HR Sports and assuming I will trim and roll fenders89' 325ix Diamantschwarz/Black rattle can...
Insta: r_moose_w
Originally posted by nando View Post+25 isn't going to fit with an 8" wide wheel. Not unless you are at stock height with small tires - won't work with a 215 or sure. Trimming won't help, even a 7" wheel will rub in the rear with trimmed lips and 205 tires at ET25.89' 325ix Diamantschwarz/Black rattle can...
Insta: r_moose_w
16 in. tires
i've got a beater ix totally stock, been sitting for 3 years got it up and running problem is the tires are kind of crapped out, flat spots. I could buy a new set of 15 in. tires but i do have a full set of 215 60 r16 less than 6 months old, came off my subaru forester ( god rest it's awd soul)
Its only for going to work and back ( 1 mile) can the subaru tires fit if i buy rims? or do i just buy new tires for the existing rims?
money is tight so i 'm trying to figure out the cheapest way.
thanksRed-ish 89 325ix with dent in the door, bad paint, missing center caps, broken defrost, broken ac, p/s pump may be going, brake pad sensors missing. On the plus side i just had the trannie and tc fixed for 2 grand!!
those are way too big. I wouldn't buy rims just to run those tires, I'm not even sure they will fit.
surely tires that fit will cost less and be better than buying new rims? Just get a set of snow tires - 15" blizzaks are like $500 installed, I doubt you could get decent wheels for much less.
this ix is on it's last legs just need to get to get me through the winter, and don't want to drop a lot of cash on it. kids and mortgage first ...
thanks will get new tiresRed-ish 89 325ix with dent in the door, bad paint, missing center caps, broken defrost, broken ac, p/s pump may be going, brake pad sensors missing. On the plus side i just had the trannie and tc fixed for 2 grand!!
skool a noob on tires
I'm wondering how much flexibility there is with tire sizes on a given rim. I've got an extra set of rims for an ix I bought a couple months ago and would like to put some snow tires on it. The guy said he used to have Blizzax on them, but I'm having a hard time finding snow tires that match the size of what's on the car now.
What I have is 205/55/15, so would it be reasonable to put a 195/55/15 on, or a 195/60/15. The 60 would be slightly larger in diameter, but I'm more concerned about the narrower width on the rim.
Any advice would be appreciated. The lake superior region on wisconsin can be icy! Thanks!
