iX wheel thread
  • two240s
    • Apr 2009
    • 395
    16x7.5 et20 and 16x9 et15. 205/45/16 all around. Rear plastics arches are trimmed underneath and fenders rolled. Fronts clear fine. H&R sports/Koni adjustables.
    • gw ix
      • 158
      15x7 Borbet type H
      • boomer
        • 3019
        BBS RX 16x7,et35.
        http://www.arghon.com/
        • 325ix
          • Aug 2009
          • 7783
          Ive been told you can't run staggered wheels on an ix. Is this true?
            • 34847
            you can provided you use the same tires on all 4 corners. it's rolling diameter, not width, that matters. Not my thing at all though - I can't imagine it would help with the stock ix's understeer tendancies.
            • 325ix
              • Aug 2009
              • 7783
              Not really my style either I was just wondering. Also would it be possible to run et0 on an ix? I know fender rolling would be required but how would you go a bout that with the flares on?
                • 34847
                offset depends on wheel width. you could run ET0 on a really narrow wheel. on an 8 or 9 inch, not a chance.
                you roll the rear fenders the same way, except you trim away the plastic on the flares where they go under the lips.
                • 325ix
                  • Aug 2009
                  • 7783
                  Thanks so would a et15 work ona 8 inch wheel? And what tire size should be used? I can't stand stretched tires on an 8 inch wheel.
                  • 2002maniac
                    • 4260
                    not a chance unless you mega stretch them.
                      • 34847
                      not a snowballs chance in hell without seriously stretched tires (maybe 195s at most).
                      double that number and you'll be closer..
                      • 325ix
                        • Aug 2009
                        • 7783
                        Ok so more like an 8 inch et38 and I wouldn't have to run streched tires?
                        What are some 8 inch wheels with a lip that would fit? I'm partial to the sportmax 002 style I'd just rather have an 8 inch wheel.
                        Thanks
                          • 34847
                          ET38 is probably too high. you would likely need a spacer up front to clear the strut. my ET36 wheels have a 3mm spacer to clear the brakes, and the tire is really close (granted they are much wider than usual).
                          try between ET35-ET30
                          • 325ix
                            • Aug 2009
                            • 7783
                            I just found a set of Drag dr-16s. They are a 16x7 in. wheel with a 40mm offset. What size of spacer would be required front and rear? Also what size of tire would you reccomend? Thanks so much for answering all of my questions.
                              • 34847
                              they will fit directly, but be far inside the fenders like stock. with a 10mm spacer you could run a 225/45-16, or a 15mm spacer for 205/50-16. if you want to push them out though you'll have to roll the rear fenders & trim the underside of the lips.
                              • 325ix
                                • Aug 2009
                                • 7783
                                would a 10mm spacer and 225s require fender rolling? I like the wider tires but I don't really want to roll my fenders
