iX wheel thread
  • Bimmer_man
    • Jan 2013
    • 1478
    #166
    Here are the wheels on my baby bbs rs715
    Float like a cadillac sting like a Bimmer!:)
    • 2002tiiguy
      • Jul 2013
      • 467
      #167
      Enkei Rpf1 17x7 et45 Click image for larger version
      • Nisse Järnet
        • Aug 2013
        • 1221
        #168
        17x7.5 ET38
        E30 325ix M50 turbo 7 spd DCT 4wd 840awhp @ 31 psi.
        E30 M50 6 spd 764whp @ 24psi.
        E30 M20 6 spd 675whp.
        • Kershaw
          • 11822
          #169
          What size tires do you run? Any issues with rubbing?
          AWD > RWD
          • slc325ix
            • Jun 2012
            • 96
            #170
            So I'm thinking of 16x8 et35 with 225/45/16 should work pretty good? Maybe a little spacer in the for the front caliper?
            • barbierij
              • Sep 2012
              • 1294
              #171
              VW 14x6 4x100 ET45 but they super slightly rubbed the tie-rod end when the car was on the lift but only when rolling backward.
              turbodiesel.com says they are called "VW flying wheels"
              They are 16lb 4oz so they are great for snows. We tried to sell them but eventually put them on a saturn SL1 for the winter. Oh yea, Saturn 14" steelies fit the e30.
              FS NY: two Audiobahn A235HC amps and audiobahn 1farad capacitor
              Saab/GM tech2 programming
              My for sale thread
              1990 325iX for sale or part out
              Did you buy something from me? Please leave feedback!
              Originally posted by K20RI_211
              And I have to ask if you make a hobby out of thread-bombing with retarded questions?
              • Nisse Järnet
                • Aug 2013
                • 1221
                #172
                Me? The car is still on stands haha so i dont know but it looks ok :)
                  • 34847
                  #173
                  everyone thinks you need spacers for the caliper. the brake spacing on an ix and a regular E30 is exactly the same, because they are the same brakes. the higher offset means the wheel fits CLOSER to the center of the car than a lower offset wheel.
                  The reason you'd use a spacer is if the tires were rubbing on the struts, or if the wheel design is such that it won't clear E30 brakes (but since they are so small, that's not too likely).
                  • slc325ix
                    • Jun 2012
                    • 96
                    #174
                    They should work then? No rolling or trimming of the flares? Would 225/50/16 look too big and not fit? There's more available tires in that size. Thanks for the info.
                      • 34847
                      #175
                      225/50 will proably not work. 225/45 should, but you'll have to check strut clearance. a 3mm spacer would give you breathing room and you shouldn't need longer bolts, although I always recommend studs instead.
                      • slc325ix
                        • Jun 2012
                        • 96
                        #176
                        Thanks for the help.
                        • CrazyPrime
                          • Jun 2014
                          • 286
                          #177
                          Would a 225/50r15 fit without rubbing on the stock ix wheel? Or would a 225/55r15 fit better I just want a little wider tires if possible.
                          • CrazyPrime
                            • Jun 2014
                            • 286
                            #178
                            Anyone?
                              • 34847
                              #179
                              225/55 is too tall. 225/50 is the right diameter. Whether it clears the struts or not is dependent on the specific tire, some run a little wider than others.
                              • CrazyPrime
                                • Jun 2014
                                • 286
                                #180
                                So I could just run a small spacer In which case it does not clear the strut, correct?
