Shorter front shocks for IX?
  • Kvasi
    • Apr 2011
    • 1122
    Aint to mutch to get in stores for the IX, but theres got to be something that fits. Anyone who knows?
  • Kershaw
    • 11822
    you're in norway, shouldnt you have like 10 pairs of custom made coilovers for the ix in your neighbors garage?
    you need to get aftermarket coilovers and cut + weld the strut tubes.
    AWD > RWD
      • 34839
      yeah, there's no benefit unless you cut the tubes down. ground control does offer a shorter insert for the ix though.
      • Kvasi
        • Apr 2011
        • 1122
        Its like my 10. BMW but my first ix, and theres not alot of them up here either so someones experience would help alot.
        I need to be able to put it back to stock when/if i want/have to. Winter can be pretty rough north of the polar circle, and almost every modification can make the licence plates dissapere.. :P
        But, what coilovers would be possible to fit in the tubes? Regular 325i 51mm?
          • 34839
          you mean put it to stock height?
          yes, any 51mm coilover kit will work
          • Kvasi
            • Apr 2011
            • 1122
            Mm, yes for wintertime. We got aprox 4 months of hell pr year up here.. :P
            Any modification has to have "TUV approval" to get the car road legal, and cutting tubes will be hard to explain and hard to undo.
            If I get pulled over that is. Its hard not to hear the turbo, so im kinka waiting for it to happen.
            Have been wondering on giving the JOM kit a try.
            Its cheap and gets a lot of thumbs.
              • 34839
              well there's no reason to use shorter inserts if you don't cut the tubes. and if you have them powdercoated I can't see how they'd even know - they'll just be ~1" shorter, otherwise indisinguishable. I'm assuming having the coilover sleeves welded on will be ok with the TUV assuming the parts have the right documents?
              • Kvasi
                • Apr 2011
                • 1122
                If theres TUV documents it should pass, if wheelspecs, and so, are fine.
                So, if a buy a set for a, feks -89, 325i touring and pull mine apart it should be straightforward to get it mounted? Got the needed equipment and know how to use it of course.
                  • 34839
                  yeah, you can use coilovers from a 325i touring, it's just the inserts that need to be ix specific.
                  a potential stumbling block are the mounts for the swaybar link. I believe you can use the stock E30 M3 peices, which might help with TUV..
                  • Kvasi
                    • Apr 2011
                    • 1122
                    Wouldnt theese be sort of a straight fit?
                    Sorry for the size of that image, and thanks for sharing knowhow :)
                      • 34839
                      the struts won't work, they're too long. you need ix specific struts, and the only place I know of that sells shorter inserts for the ix is Ground Control (they're konis so TUV should be OK?).
                      you can use the springs and rear shocks though.
                      • Kvasi
                        • Apr 2011
                        • 1122
                        Yeah, konis should be TUV ok. Only IX specific i can find is camber plates at G/C homepage. Think ill send them a mail and see.
                        Again, thanks. More used to pickups and liftkits lately.. :P
