Regular rear diff in an IX
  • lolcantturn
    • 4588
    Just wondering if you have a matching viscous front 4.10 diff, can you put a regular E30 clutch pack 4.10 rear diff in an IX ?
    Originally posted by TSI
    OEM+
  • flyboyx
    • 8371
    you can. too bad there is no counterpart for the manual cars.
    Gigitty Gigitty!!!!
    • lolcantturn
      • 4588
      Yeah this is going in an automatic IX
      OEM+
      • edsta74
        • 108
        i was wondering this myself. I have an automatic 1990 ix and Im actually looking into replacing my rear diff. I read that the ix has a specific viscous type diff. And that it has a medium case. would there be any problems with installing a clutch type diff with a small case? Or should i just keep looking for the "right" one. Im in no hurry.
          • 34839
          it will physically work. whether it will perform as well - I have no idea. I'm sure a VC diff cost more than a clutch pack diff, so BMW must have used it for a reason.
          • nomansland92
            • 1657
            I think I read somewhere the ix diff is 90% locking.
            IX being restored here
            Ix turbo build here
            • matt0300
              • 549
              if ur going to replace it get a clutch type diff i have beef with viscous diffs lol. make sure its the same ratio as ur front diff or else ur gonna destroy ur tcase. urs is an auto so u should have a 4.10. oh and another question is the ix 4.10 viscous or clutch? cause i know my 5 speed was a 3.91 viscous.
                • 34839
                good thing you don't know what you're talking about. :p
                • matt0300
                  • 549
                  • Chruby99
                    • May 2011
                    • 262
                    Some local e30 guys I met at the junk yard suggested upgrading the diff in my iX. I asked them the difference and they said the clutch setup was beefier for say drifting. And I can understand If I were in an M50 rwd setup. You could probably cook the vicious diff. easily. But with the AWD I do not see having that problem. I have an auto with a vicious rear and it appears to operate the same as a posi on jack stands. I cannot see any reasons it would not be recomended as a replacement for the visc. dif.
                    • Chruby99
                      • May 2011
                      • 262
                      The diff is not the ring. If you are pulling the diff you would reuse the ring and pinion. I am not familiar with the bmw rear ends as I have yet to open mine up and take a look. But if the Posi is out of the same size case You should be able to swap the diff and reuse everything else.
                      • matt0300
                        • 549
                        Huh? I'm lost now. I like the idea of viscous diffs but they fail a lot faster then clutch. What makes them good also makes them "bad" in my opinion.
                        • Kershaw
                          • 11822
                          it's 10-100% lock up.
                          standard clutch pack diffs only have a 25% lock up. but where im confused is that it really shouldnt be rated in percentages, because power can change but clutch packs dont magically breed. i think its something around 65ft/lbs is the break away.
                          im not sure if it's called 100% lock up because the viscous has a break away torque spec at 160ft/lbs.
                          AWD > RWD
                            • 34839
                            no, they don't. they only fail if you abuse them.
                            • matt0300
                              • 549
                              Granted that's true for any diffs Lol. Do u like vlsd's more?
