IX wheel fitment
  • Driftin
    • Jan 2011
    • 129
    IX wheel fitment
    So, yet another will these fit thread, but I think I know the answer as I have been searching and researching.
    I am looking at a set of wheels locally that are 15x7 et26. Supposedly on a honda right now. Tires are Falken Ziex 205 50 15.
    My research indicates that these will fit with no rubbing inssues. Is that correct? I am running H&R sports with Bilstein HD and trimmed bumpstops.
    If I can get a definitive yay, I am going to pull the trigger. Thanks guys.
  • Kvasi
    • Apr 2011
    • 1122
    How wide are the rims? Guess it should work fine, ive got 7.5x17 et22 on mine.
    • Driftin
      • Jan 2011
      • 129
      Rims are 15x7 et 26.
        • 34844
        they will fit OK. may rub in the rear if you are lowered. you can trim the inside of the plastic flares and roll the fender lips for clearance.
        • nomansland92
          • 1657
          You should be fine, I've seen et20 on IXs before. I think they were on 16x7's
          IX being restored here
          Ix turbo build here
          • audiquattrot
            • May 2008
            • 3836
            my Alpinas are 16x7 ET28, lowered on H&R Springs. No rubbing issues whatsoever. 205/55/16's i believe
            you should be fine
            www.instagram.com/snwmble
            #snwmble
            Current:
            '05 BMW M3 - Silver Grey/Imola Red
            '90 BMW 325iX - Sterling Silver/Houndstooth sport(5-speed converted)
            '15 Mini Countryman - Blazing Red/Carbon Black
            Past:
            '01 Audi Allroad - Light Silver/Platinum Saber Black
            '88 BMW 325iX - Diamond Schwarz/Silver sport *Sold*
            '01.5 1.8TQ - Brilliant Black/Nogaro Alcantara ...after 8.5yrs, *Sold* =(
            '90 BMW 325i - Schwarz/Tan sport *Sold*
            '89 BMW 325ix - Diamond Schwarz/Black sport *Sold*
              • 34844
              that's still 2mm further in. you probably have 205/50-16 as 205/55-16 are pretty seriously oversized. :p
              I think it will rub, but it will be really close - like within a waffleswaffleswaffleswaffleshair.
              • audiquattrot
                • May 2008
                • 3836
                yes ur right! i have 50 series. I always get the ET #'s mixed up! E26 will stick out a lil further.
                #snwmble
                Current:
                Past:
                • Driftin
                  • Jan 2011
                  • 129
                  I'm gonna buy 'em. If I have to roll the fender a smidge, no big deal. Thanks for the info guys.
                  • Kershaw
                    • 11822
                    i had a rim with those specs. it rubbed a slight bit under really hard cornering in the rear.
                    not a problem at all. i was lowered and no trimming or rolling.
                    AWD > RWD
                    • TOAST
                      • Jan 2006
                      • 316
                      taking advantage of yet another wheel and tyre thread...
                      Offset: 35mm
                      Backspacing: 5.41"
                      Bolt Pattern: 4-100
                      Rec. Tire Size: 205/50-16
                      can i wrap some beefy on them or should i stick with the Rec. Tire Size?
                        • 34844
                        Originally posted by TOAST
                        Offset: 35mm
                        Backspacing: 5.41"
                        Bolt Pattern: 4-100
                        you should be able to fit a 215/45 or so on there just fine. it really depends more on what's available in + sizes. I'd go for a better compound over a wider tire any day.
                        • GJ@GA_US
                          • 46
                          Non Lowered 325ix w / Ronal LS 15" 4x100 et25. I haven't bought a set of these yet, but want to. I need to undestand the implications. What is the best tire size? How does the stance look? What is the driving dynamic like? Is there any sacrifice?
                          If this question has been asked before my appologies, I did a search but came up with nothing.
                          Thanks
                          GJ
                            • 34844
                            they should fit with 205/55-15s (stock size) but might look a little bit pokey with the low offset/high ride height. but shouldn't be bad at all.
                            are they 15x7 or 7.5? with 7.5 there's a chance they may rub sometimes in the rear but not nearly as bad as a 7.5" wheel with a 20mm offset.
                            • Northern
                              I like cupcakes & sh!tboxes
                              • 5284
                              I assume stock 14" basketweaves (14x6.5 et30) with 195/70/14's should fit a stock height ix with no issue?
                              Originally posted by priapism
                              Originally posted by shameson
