You guys ready for the winter?
  • M-technik-3
    • 18946
    #31
    Originally posted by gr8skyr
    M-technik-3....are those the OZ superleggara? Nice if so. Wish the new ultraleggara came in a 15", and was as light as those! 4 lug and I'd have been interested when available.
    Correct Superleggera's in 17x8 et40 for E36.
    • irish44j
      • 2763
      #32
      Yeah, I'm ready.
      My e30 will be in the garage getting an engine swap. Luckily, I have a few better vehicles for the winter anyhow :)
      Stage rally/rallycross e30 build/competition journal
      Track/street e21 build
      visit Condor Speed Shop
      visit Motorsport Hardware
      [FONT="Franklin Gothic Medium"] 1985 318i/M50 Rally Car - 1988 Porsche 924S - 2005 Sequoia tow pig - 2018 GTI
      • madman23
        • Jan 2007
        • 498
        #33
        Adding coolant since my light is on, switching to blizzaks and removing my front lip. Thats about it. Haha
        • Northern
          I like cupcakes & sh!tboxes
          • 5283
          #34
          The new "good to go" ix needs a patch in the rear drivers wheel well, a license plate light hole re-created. (One is welded shut, the other cut out 2x the size) and a new subframe, since only hopes and dreams are holding the TA's on to this car.
          After that, oil and a peek at the timing belt to see if it has any signs of wear/age. If not, it is getting deferred till the spring.
          Hopefully nothing else crops up
          Originally posted by priapism
          Originally posted by shameson
          • M-technik-3
            • 18946
            #35
            4x4 status looking for some mud soon. Swapping back to my Toyo's I think since these are so thick. No need for stinking AWD when you run 4 snows.
              • 34844
              #36
              no, but it sure is a lot more fun. :D
              • M-technik-3
                • 18946
                #37
                Yeah, finally kicked my open diff to the curb and put a proper LSD in it.
                • gr8skyr
                  • 228
                  #38
                  My $263 Winter update!
                  $50 craigsist AR rims- shed find circa 1997.
                  $100-Some old but still got some tread and metal Hankook tires craigslist
                  $48 AR lugbolts from Summit Racing
                  $10 70.5-57.1 hubcentric rings
                  $55 Les Schwab to mount, balance and swap them on.
                  "just love those little tanky inline 6's"
                  • M-technik-3
                    • 18946
                    #39
                    Very cool Good winter kicks.
                    • shadowman
                      • Jan 2008
                      • 49
                      #40
                      What do you think of running 195/65/15 for winter?
                      • A Sucked Orange
                        • 707
                        #41
                        Think I'd rather go smaller/thinner.
                        • psmura
                          • Mar 2012
                          • 119
                          #42
                          That's what I run, hankook ice pike no problems. Any snow tires should be fine on the ix nothing bigger or you'll likely rub.
                          1989 325ix
                          1992 325ic 770A
                          2002 M3
                            • 34844
                            #43
                            it really depends on what kind of conditions you're likely to see.
                            if it's mostly deep snow, then you'll want tall/thin. up here it's mostly going to be rain and ice, and some dry days. 195 is already narrower than stock, and in my case I wouldn't want to go narrower. I would have chosen a 205/55R15 if it were available, but 195/60R15 is really close to the stock diameter.
                            a taller tire will have more straight line traction than a shorter one, but then your sidewalls are also 5% taller. I find the 195/60R15 to be quite squishy as it is, and in my conditions it's not needed.
                            • shadowman
                              • Jan 2008
                              • 49
                              #44
                              thanks for the inputs guys.
