New set has arrived! Front shaft uppgrade *Finland-Fix*
  • audiquattrot
    • May 2008
    • 3836
    #136
    awesome thank you!
    www.instagram.com/snwmble
    #snwmble
    Current:
    '05 BMW M3 - Silver Grey/Imola Red
    '90 BMW 325iX - Sterling Silver/Houndstooth sport(5-speed converted)
    '15 Mini Countryman - Blazing Red/Carbon Black
    Past:
    '01 Audi Allroad - Light Silver/Platinum Saber Black
    '88 BMW 325iX - Diamond Schwarz/Silver sport *Sold*
    '01.5 1.8TQ - Brilliant Black/Nogaro Alcantara ...after 8.5yrs, *Sold* =(
    '90 BMW 325i - Schwarz/Tan sport *Sold*
    '89 BMW 325ix - Diamond Schwarz/Black sport *Sold*
    • jute91
      • Nov 2011
      • 581
      #137
      If you want to track it
      Track your parcel by entering the tracking number in the tracking field. View real-time updates on your parcel's journey and delivery status.
      Also found on Facebook - Juuso Tero, Tampere
      https://www.facebook.com/JuusosGarage
      • audiquattrot
        • May 2008
        • 3836
        #138
        Ugh machine shop lost the nipple that goes into the side that u can feed grease into. Any chance u can send me a couple and ill paypal u?
        #snwmble
        Current:
        Past:
        • TehRaydarlover
          • Mar 2013
          • 544
          #139
          It's just a zerk fitting, can get one at any hardware store. Threads might be metric?
          Build Thread
          Rear Diff Rebuild
          Rebuildable Viscous Coupling
          Transfer Case Rebuild
          "Life is simpler with 12 valves"
          • audiquattrot
            • May 2008
            • 3836
            #140
            Ahhhh good to know! Jute would u happen to know what size fitting?
            #snwmble
            Current:
            Past:
            • audiquattrot
              • May 2008
              • 3836
              #141
              #snwmble
              Current:
              Past:
              • Nisse Järnet
                • Aug 2013
                • 1221
                #142
                Looking good!
                E30 325ix M50 turbo 7 spd DCT 4wd 840awhp @ 31 psi.
                E30 M50 6 spd 764whp @ 24psi.
                E30 M20 6 spd 675whp.
                • jute91
                  • Nov 2011
                  • 581
                  #143
                  yes the thread is metric m6x1. You should been able to buy it from any shop
                  • jute91
                    • Nov 2011
                    • 581
                    #144
                    How many km/miles have you guys driven with my mod? I'd like to get some feedback, have I done my work right :P
                    • audiquattrot
                      • May 2008
                      • 3836
                      #145
                      i'm saving mine for a rainy day, until my current one shits on me!
                      #snwmble
                      Current:
                      Past:
                      • dinan3
                        • 52
                        #146
                        Question. Any reason (as long as the splines are in good shape) we couldn't cut the existing driveshaft in the middle, add similar diameter tubing and weld it back together to extend the drive shaft?
                        There is enough splines on the original shaft, we just want another inch or two of engagement, right?
                        I think the upgrade kit is a great idea if your splines are worn, but I'm also looking for a cheaper interim solution.
                        Sent from my iPad using Tapatalk
                        • TehRaydarlover
                          • Mar 2013
                          • 544
                          #147
                          Your not going to get too much more thread engagement out of the stock head, maybe a 1/4in. If you make the stock shaft longer then you'll have to drop the t-case or front diff to get it in and every time you want to grease it. If you want to get a little more engagement on the cheap just use a spacer like others have been doing for a long time.
                          Ray
                          Build Thread
                          Rear Diff Rebuild
                            • 34847
                            #148
                            don't wait until it strips. it'll just damage the output sprocket of your transfercase. no bueno.
                            • jute91
                              • Nov 2011
                              • 581
                              #149
                              maximum engagement with stock shaft is ~30mm. stock setup uses about 18mm of it. the stock output sprocket has splined lenght around 60-61mm.
                              this version of mine uses 50mm of it. also, you need to think about the sealing. If you push it too far, the O-ring might not be sealing if it drops out of the plastic cover
                              • dinan3
                                • 52
                                #150
                                Thanks all, I have a spare shaft that I am going to do the upgrade on.
                                I did add spacers to mine but I now have learned you only have so much room before contact would be made to the bell housing.
                                What exactly does the X5 center piece add as far as functionality? More center pin engagement? Also is there anyway to remove the front driveshaft without other major components?
                                For an automatic the fluid fill tube wraps around and under the driveshaft...
