New set has arrived! Front shaft uppgrade *Finland-Fix*
    • 34829
    #106
    Originally posted by jute91
    Still have them... around 20pcs.. 190 + 45 shipping, total 235 usd shipped. for nando I can give some retail for 2 ;)
    I'll send you a PM..
    • rzerob
      • Jun 2013
      • 2315
      #107
      I guess I am going to have to do this too.
        • 34829
        #108
        just got my pair yesterday! shipping was quick, I just paid last week - and these things are nice! I love that they have a grease nipple, that will make keeping them lubricated sooo much easier.
        • jakeb
          • 1909
          #109
          PM sent
          www.classicdaily.net
          1970 m42 swapped 2002
          1985 LS1/T56 Swapped e28 (557e)
          www.blunttech.com - For all your parts needs
          Follow me on Instagram for constant build updates @classicdaily
          https://www.facebook.com/ClassicDailyLLC
          • The Dark Side of Will
            • Jun 2010
            • 2796
            #110
            What would it take to do a run of between 1 and 5 of these, with a different driveshaft end?
            What I'd like is for the driveshaft end of the fitting to be able to accept a BMW 4 bolt driveshaft flange, either from the 168mm E46 front diff (pictured) or from the 188mm or 210mm units.
            That way, I can install the fitting into the T-case, install the flange to the fitting, then build a u-jointed driveshaft to use an E53 oil pan in a 24V or 32V swap.
            [ATTACH]87529[/ATTACH]
            [ATTACH]87530[/ATTACH]
            • jute91
              • Nov 2011
              • 581
              #111
              Not sure but I guess they run same sized driveshaft pipe? whether not, you can always make an adapter between pipe and shaft head.. ;D
              Also found on Facebook - Juuso Tero, Tampere
              https://www.facebook.com/JuusosGarage
                • Jun 2010
                • 2796
                #112
                No driveshaft pipe... I just want to bolt an extra flange right to the shaft you make.
                • jute91
                  • Nov 2011
                  • 581
                  #113
                  Sure why not, pay some extra and I will make a flange for you and weld it on. make me a some kind of drawing
                  • Nisse Järnet
                    • Aug 2013
                    • 1221
                    #114
                    I want a E34 lengthened piece please :D
                    E30 325ix M50 turbo 7 spd DCT 4wd 840awhp @ 31 psi.
                    E30 M50 6 spd 764whp @ 24psi.
                    E30 M20 6 spd 675whp.
                    • jute91
                      • Nov 2011
                      • 581
                      #115
                      well just send me you shaft and measure the dept of the tc housing
                      • Nisse Järnet
                        • Aug 2013
                        • 1221
                        #116
                        Can u PM the price if i send u the shaft and make a piece and weld it on and send it back?
                        • jute91
                          • Nov 2011
                          • 581
                          #117
                          Can you send me a picture about it? measure diameter of the splined area?
                          If I need to make complete new head for it, it's going to be expensive.
                          Since I need to order more steel for it because I used all into e30 shafts, its going to cost. And If you're going to be the only one for order, it aint cheap.
                          Hope the head is same than in e30...
                          • Nisse Järnet
                            • Aug 2013
                            • 1221
                            #118
                            Splined area is 29,5mm.
                            • jute91
                              • Nov 2011
                              • 581
                              #119
                              Not even close.. looks like it has less teeth and deeper profile..
                              Looks like I need to buy e34 transfer case and front shaft for this one
                              • Nisse Järnet
                                • Aug 2013
                                • 1221
                                #120
                                Maybe i can send you the parts you need?
