325ix Transfer Case DIY ( originally written by juubi)
  • jute91
    • Nov 2011
    • 581
    Hi all!
    I spoke with my finnish friend Juubi about translating his DIY to english... so here you go.. correct my language please :)
    Original page here: http://juubi.hlan.net/index.php?page...x/transfercase
    So the car is BMW e30 325 -89
    Parts used in service:
    Seals 2x ( front shaft)
    Seal for rear shaft
    Seal for input shaft
    paper gasket for case
    ATF oil 0.5 litre
    Transmission oil 1.25 litre
    So i noticed need for service when i was driving snowy road with summer tires on. All went fine till
    rear end started to slip and torgue was lost from the front end fully to rear. I was able to proceed
    moving with lot of throttle but thinking about traction there was no any reason to continue this way.
    So viscous coupling located in transfer case has come to the end of its life.
    Factory Brand new viscous would cost something around 2000 euros, so that wasn't even a option for me.
    Viscous is assembled in the vacuum space, welded by robot, so i thought that it would not be reliable
    option to repair it myself. Only changing the viscous coupling makes that much work that changing it
    just for a test would be unnecessary. Luckily i found
    full TC for suitable price, which had fail on its front axle splines. Transfer case that i bought included
    100k km drived viscous, but at this part i could not test it but only rotating by my own hands..
    The repair itself started by removin exhaust, exhaust covers, front shaft, transfer case support and rear shaft.
    Dropping of the engine was quite fast attempt. Needed to remove front subframe bolts, steering rack,
    power steering and radiator hoses. After that i was able to drop engine for transfer case remove.
    Dropping of the engine pictured in front of the car.
    I needed jack with support tranny so i supported engine with the chain.
    After removing all the parts and lowering the engine, i was able to remove the case itself.
    Transfer case is bolted to the tranny with 4 bolts, also jointment between tranny and T case has 3 bolts per flange.
    Removing these bolt will drop the transfer case.
    Transfer case ready for service and change of viscous coupling.
    Case had some oil leak from breather and front seal. Glory itself was washed with pressure washer and all hardened oil
    was removed from the case before starting to tear it apart.
    I choosed best parts from these two transfer case and build it togehter.
    After that i was able to start disassemply.
    Shell will split after removing all M8 bolts off around shell. It needs little rubber hammer because 2 liners.
    on the background you will see car front end and drive shaft of the other side..
    Disassemply of T-case
    After splitting shell you lift gear off with the puller, rest of the parts will loosen with rubber hammer
    Checking chain
    My old chain felt little loose. You can measure chain looses by twisting chain on cross-direction,
    over 200k km is able to see on this chain.
    comparing old chain to newer..
    Viscous next to each other
    Here is my spare and old viscous. It is impossible to measure the condition of viscous by eyesight but
    in this case you couldonly guess which one is cleaner
    Now its right time to replace seals to T -case.
    There is no any counterface for seals where to tap new ones. You should measure the depth before removing old one.
    At this part i used washers to measure correct depth.
    To be continue...
    After installing all seals, I was able to start put it back together
    It all started by installing input shaft to case. Its locked with lock ring.
    Then its time for gear and viscous crown.
    Then you drop the planet gear onto it.
    for a point on a "i" you'll drop the unbroken viscous onto it.
    Preparing the rear cover
    Chancing rear cover seal is done by same technic like i showed earlier. Using washers.
    Here is Ix's saddly failed front output gear. Luckily i got another one with splines that are in good shape.
    Installation of chain, i took old bearing from spare T case, which was in better condition.
    All things together, ready to install rear cover
    Making of gasket
    Cover installed
    While Transfer case is off, you should check your tranny output shaft seal too and all rubber mounts etc.
    then you can start to put it all back together..
    Also found on Facebook - Juuso Tero, Tampere
    https://www.facebook.com/JuusosGarage
  • Danny
    • 14216
    I fixed all the images for you.
    Thanks for the write up!
    • jute91
      • Nov 2011
      • 581
      Thank you for that! :) Enjoy!
      • imwhyteyo
        • 1165
        Awesome. Used alot of this info today replacing the seals in my 200k+ tc. Luckily my vc was still in great shape(after bench testing). Inside my case was a bit ugly with buildup. But is clean now and leak free.
        • downforce22
          • Aug 2009
          • 3192
          Wow this should be a sticky, i missed this when it was posted last
            • 34839
            Can you get new chains in europe? Borg Warner says they are NLA. Talking to them to see if that is forever.. BMW wants $1000. :(
            My brand new VC was only $578 back in January.
            • Nisse Järnet
              • Aug 2013
              • 1221
              A new chain for E34 is around $600, i can check the price for the E30 text week.
              E30 325ix M50 turbo 7 spd DCT 4wd 840awhp @ 31 psi.
              E30 M50 6 spd 764whp @ 24psi.
              E30 M20 6 spd 675whp.
                • 34839
                it's probably made by the same factory but it's a different width (and likely length).
                I'm still hopeful since it's made of commodity parts (standard links), they just add more links for the length and stack them for the width. so they can still make them, but I don't know if they'd want to make a small run of something like 10 or 100..
                • Nisse Järnet
                  • Aug 2013
                  • 1221
                  Yes both are ZF and i got the price from the Swedish ZF importer :-)
                  Ill get back with a price on the E30 chain.
                  Anyone got the ZF part number on the E30 tc btw? Should be a sign somewhere with numbers.
                    • 34839
                    ZF-95a I believe?
                    the chain is HV-024 for early and HV-024R for late.
                    it's possible there are a few of them sitting around in warehouses at different transmission places.. maybe I'll get lucky, they're listed at under $200 in a couple places - but you have to call to confirm they even have it. :)
                    • Nisse Järnet
                      • Aug 2013
                      • 1221
                      ZF-95a I believe?
                      Thats the model but the part nr should be ten digits usually in three groups like xxxx-xxx-xxx.
                      Im sure its more expensive then $200 =S
                        • 34839
                        They were only $130 a few years ago
                        • jute91
                          • Nov 2011
                          • 581
                          Bought my new chain + seals + some of bearings from Turner motorsport.
                          Was that about 300$? They ordered it from Germany to USA and sended to Finland, lol.. new chain would have been cost 1000$ from here
                          • jute91
                            • Nov 2011
                            • 581
                            ask from dugmar@turnermotorsport.com about new chain
                              • 34839
                              have you asked recently? I'm thinking they'd get it from BMW, and BMW prices are insane now. I'm hoping to score one directly from the manufacturer as it was much cheaper..
                              I'll ask though. I also need a new front output sprocket..
