325ix Transfer Case DIY ( originally written by juubi)
  • boogle2
    • Dec 2014
    • 114
    #31
    sub'd. Winter project for me.
    2011 335i xDrive Msport - sold
    2002 M5
    '88 325ix turbo build :D
    • notanawdix80
      • Apr 2017
      • 111
      #32
      Hi. Sorry to revive an old post, but i've been searching in forums about my problem and can't find a resolution
      My car has the VC dead, and i don't plan on repairing it, the costs in my country are too high.
      Is there any consequences by removing the TC Chain? I have a gear noise behind my seats and i think it's coming from the TC Chain slipping. I've got the front drive shaft disconnected so it's not a front diff or splines problem.
      Thanks
      edit: the slipping gear noise is only at 800-1000 rpm when i'm starting to move
        • 34830
        #33
        if your VC is dead the best thing would be to leave it alone.
        if you removed the chain, the car would no longer move. The way the planetary gear works without the VC is like an open differential - all the torque goes to the end with the least amount of grip. With the chain removed, the front would effectively have "zero" grip and all the torque would go there.
        The chain slipping doesn't sound like a gear noise anyway. It's more like nuts and bolts in a blender.. but if it's really slipping, your TC is in need of repair or replacement anyway, because along with the dead VC the car will no longer move once it gets really bad due to the reasons listed above.
        • notanawdix80
          • Apr 2017
          • 111
          #34
          Thanks for the fast reply nando.
          I'll leave the TC alone and inspect the rest of the components in the drivetrain. Guibo u-joints etc
          Other problem on my ix is lots of vibrations at high speeds, from 80 mph to 110mph. Feels like my dash is falling apart. And so is the steering
          Thanks again
          • ghatid
            • Sep 2013
            • 151
            #35
            Thanks again
            Wow, do you often drive around at 110mph with your e30? Not sure how mihne would hold up.
            • notanawdix80
              • Apr 2017
              • 111
              #36
              It holds up pretty well. Car feels stable and keeps pushing.
              Not often, i was just testing it.
              • bankrupt
                • Aug 2015
                • 61
                #37
                Hola argentina��
                Check the driveshaft flex disk and the ujoint. Mine shaked terribly above 60mph. I replaced the whole driveshaft cause no one around here could fix ujoint and balance the shaft. Buena suerte
                • notanawdix80
                  • Apr 2017
                  • 111
                  #38
                  Originally posted by bankrupt
                  Hola argentina��
                  Thanks for your reply.
                  I'll be doing that next week. It will be impossible to find an ix driveshaft in my country. I only know five 325ix and no parts for sale.
                  I've heard of people doing u-joints repair so i will try that. Then i will create a new thread with info about it
                  • notanawdix80
                    • Apr 2017
                    • 111
                    #39
                    Thanks for the reply. I've heard of people repairing u-joints near my place.
                    Acquiring another driveshaft would be impossibe. Ix's are an exotic thing and there arent even parts for it.
                    • Kershaw
                      • 11822
                      #40
                      Check eBay. Some sellers will ship worldwide.
                      AWD > RWD
