3.1L turbo ix
  • TehRaydarlover
    • Mar 2013
    • 544
    3.1L turbo ix
    Theoretically :drink:what would I need to do to accomplish this?
    lots o $$$
    IE 3.1 kit?
    _________ turbo?
    New front diff
    Build Thread
    Rear Diff Rebuild
    Rebuildable Viscous Coupling
    Transfer Case Rebuild
    "Life is simpler with 12 valves"
  • ak-
    • 12422
    a lot of spare transfer cases
    1991 325iS turbo
    • TehRaydarlover
      • Mar 2013
      • 544
      Suggested upgrades?
      Build Thread
      Rear Diff Rebuild
      • acolella76
        • 2950
        I believe there's already a few turbo iXs out there... some that put down some srs horsepressure. Search e30tech.com
        -Alex
        • nomansland92
          • 1657
          I'm currently boosting my ix. The biggest thing you'll need is to extend the front drive shaft. There's a few ways about doing this, spacers, bigger gubio, or welding on longer splines. There's a guy here that sells longer splines. The rest of the drive line is pretty good. Obviously you'll want to get a better clutch as well.
          There's a few 500+hp ix around on the forums, I've heard they've been holding up pretty well also.
          IX being restored here
          Ix turbo build here
          • MF DOOM
            • Apr 2012
            • 944
            The swedes have built some filthy IXs.
              • 34844
              Not really
              • ak-
                • 12422
                Originally posted by nando
                Not really
                Do u even iX?
                1991 325iS turbo
                • flyboyx
                  • 8371
                  actually, a lot of spare front diffs
                  Gigitty Gigitty!!!!
                  • StinkE30
                    • 155
                    Do u even iX?
                    Surely, you must be trolling.
                    • TehRaydarlover
                      • Mar 2013
                      • 544
                      Is lengthening the splines going into the front diff the only thing you can do to strengthen it? Replace it?
                      Would the vc be able to handle the power?
                      Build Thread
                      Rear Diff Rebuild
                        • 34844
                        The transfercase doesnt work like that - also, drivetrains are rated by torque, not HP.
                        • downforce22
                          • Aug 2009
                          • 3192
                          Nando brings up a great point. By definition a transmission and diff combination is a torque multiplier.
                          The max torque of a stock m20 is 164 ft-lbs at 4300 RPM. Full throttle in first gear in an iX is not a big deal because it does not break transfer cases, front diffs, or axles. To find the torque multiplier of your car multiple the desired gear ratio by the final drive ratio. American iX's came in only 3.91(manuals) and 4.10(autos) final drive ratios. Also the first gear ratio in the manual is much higher than the auto (3.83 vs 2.48).
                          1st gear manual with 4.10 diffs:
                          Torque multiplier: 3.83 * 4.10 = 15.703
                          Max torque seen by driveline: 15.703 * 164 ft-lbs torque = 2575.3 ft-lbs.
                          2nd gear manual with 4.10 diffs:
                          Torque Multiplier: 2.20 * 4.10 = 9.02
                          Max torque seen by driveline: 9.02 * 164 ft-lbs = 1479 ft-lbs.
                          This pattern continues; as the torque multiplier decreases in higher gears the torque seen by the axles is also lower. Therefore the most torque applied to a drive line is in a manual iX with 4.10 diffs accelerating at 5800 RPM in first gear. At the worst case scenario of a stock m20, the iX driveline has to be able to handle 2575.3 ft lbs in the axles. I think it is fair to say the transfer case and diffs are adequately built to handle this much power. So how can this be used to our advantage? If we work backwards from 2575 ft-lbs we can find the torque the driveline can take in different gears before we are exceeded the known power rating of the driveline.
                          Max torque before exceeding stock drive line safety levels
                          2575.3 = x * 15.703, x = 164 ft/lbs torque in first gear (duh)
                          2575.3 = x * 9.02, x = 285.5 ft/lbs torque in second gear
                          2575.3 = x * (1.40 * 4.10), x = 448.6 ft-lbs torque in third gear
                          2575.3 = x * (1 * 4.10), x = 628 ft-lbs torque in fourth gear
                          2575.3 = x * (0.81 * 4.10), x = 775 ft-lbs torque in fifth gear
                          Remember I calculated this with 4.10 diffs for worst case scenario but the regular 325ix manual has 3.91 final drive which would actually result closer to 300 ft-lbs torque in second gear. What I am getting at is that unless you are launching the car in first gear, you should be fine with the iX driveline, just dont be stupid.
                          • TehRaydarlover
                            • Mar 2013
                            • 544
                            Great info. I wonder what kind of factors of safety bmw used in the drivetrain.
                            Sorry I was talking about lengthening the axle shaft splines going into the front diff. Forgot to quote nomansland92
                            Build Thread
                            Rear Diff Rebuild
                            • downforce22
                              • Aug 2009
                              • 3192
                              This is something I wonder about too, especially considering q5quint's iX (not wildkarrde has it), mw255's turbo in finland, and ss45466's turbo all were pushing the drivetrain.
