Headers?
  • Bolestuff
    • May 2012
    • 51
    Headers?
    What headers are considered the best fitment and price out there for the ix?
  • Bolestuff
    • May 2012
    • 51
    Wow, thanks for the input everyone! I just bought the miller MAF, 19lb injectors, and some headers. With the signature motorsports cai, magnaflow muffler, and a chip I think the gains should be great. Anyone running a similar setup?
    • TehRaydarlover
      • Mar 2013
      • 543
      I don't think there are too many restrictions with headers for the ix, so whatever is the best price/fitment for a normal e30. I just have stock now but am thinking about some bravauto ceramic coated long tubes. The only thing to worry about is the cv boot getting too hot and prematurely failing, hence ceramic coated.
      Build Thread
      Rear Diff Rebuild
      Rebuildable Viscous Coupling
      Transfer Case Rebuild
      "Life is simpler with 12 valves"
      • WarHammer 2/1
        • Sep 2013
        • 190
        You know about the bavauto header group buy going on right now?
        • TehRaydarlover
          • Mar 2013
          • 543
          Yeah I saw that. Not quite ready for performance upgrades yet, still working on maintenance.
          Build Thread
          Rear Diff Rebuild
          • Bolestuff
            • May 2012
            • 51
            Thanks for the input, I have the car in the shop right now getting headers and a new high flow cat!
            • Bolestuff
              • May 2012
              • 51
              Headers help this car all over the place!
              • Bolestuff
                • May 2012
                • 51
                Just got my Miller MAF and 19lb injectors, should get about 20hp to the wheels. I will dyno and report back my numbers.
                  • 34835
                  Youre dreaming if you think youll get 20whp, but enjoy.
                  • fresh_TD
                    • Aug 2013
                    • 2457
                    So how about those dyno results?? What i did was match port everything..head, intake/exhaust manifolds..runs great
                    Sent from my GS4 Active
                    '91 318i (Alpine) - daily
                    '88 325ix (Zinno) - drive here and there!
                    • Bolestuff
                      • May 2012
                      • 51
                      This is from Miller https://www.millerperformancecars.co...III%202.5L.pdf
                      I called them out on it and they admitted it was more like 15, but that is with the old 14.5 single port injectors. Regardless, I will post a dyno run of my own in a month or so. So I guess dreaming is not really accurate. What kind of gains are you thinking?
                        • 34835
                        Id be impressed if you break 150whp on a dynojet
                        Not hating on you, I'm sure it will be an improvement, but 20whp on an ix is a big task from a small motor.
                        • ForcedFirebird
                          • Feb 2007
                          • 8300
                          Not sure about with the Miller stuff, but I just got well over 150 with RD headers, one of our stock rebuilt heads, and our dyno chip tune. No porting, stock AFM etc. 200+k mile bottom end RWD e30, so an ix will be lower.
                          EDIT: 155.26whp/154.16wtq as you can see, the chip was only worth about 2whp/3wtq.
                          john@m20guru.com
                          Links:
                            • 34835
                            Yeah but this is an ix, that puts down maybe 140whp stock. Eric Johnson's only put down 125. I saw a 3 liter IE Stroker do 150 (needed a tune, but still).
                            20Whp is just nonsense. That would be ~200 at the crank on an otherwise stock motor. It doesn't pass the BS test.
                            • ForcedFirebird
                              • Feb 2007
                              • 8300
                              Yes, my point exactly. I have tuned numerous cars on the dyno, we have thousands of graphs just from this year alone, the only time we saw any kind of big gain was on my personal car which went from 124whp to 148, but that's because the WOT switch on the TPS is broken and instead of changing it (being lazy), just tuned it out lol.
                              john@m20guru.com
                              Links:
