24V AWD Swap Knowledge Base
This is a sticky topic.
    • 34827
    #361
    the E46 rack has better clearance for the front diff but the subframe needs modified for it to fit.
    • The Dark Side of Will
      • Jun 2010
      • 2796
      #362
      Originally posted by nando
      nice!
      I was going to give up on it, but after going back and forth between my E90 and the ix, I'm definitely going to try and make the E46 rack work. The E30 steers like a bus in comparison to the E90. my 385mm Mtech-II wheel doesn't help either.
      I have an E46 Xi rack, so I can include mounts for it and at least try to make sure it clears everything else that bolts to the crossmember.
      • Nisse Järnet
        • Aug 2013
        • 1221
        #363
        Ok thanks, that will have to wait for next year i think :)
        E30 325ix M50 turbo 7 spd DCT 4wd 840awhp @ 31 psi.
        E30 M50 6 spd 764whp @ 24psi.
        E30 M20 6 spd 675whp.
        • Nisse Järnet
          • Aug 2013
          • 1221
          #364
          3mm clearence between brake rotor and tie rod should be ok?
          • flyboyx
            • 8371
            #365
            yes, thats probably what it is from the factory.
            Gigitty Gigitty!!!!
            • Nisse Järnet
              • Aug 2013
              • 1221
              #366
              Great, didn't measure stock setup :)
              Now its time for caliper adapters!
              • AWDBOB
                • Aug 2013
                • 4377
                #367
                Nisse, start a build thread already!!
                • iXguido
                  • Nov 2009
                  • 721
                  #368
                  are those m3 rotors?
                  • flyboyx
                    • 8371
                    #369
                    i don't know what he has in the pic, but e36 m3 rotors work perfectly on e34 ix hubs.
                    Gigitty Gigitty!!!!
                    • Nisse Järnet
                      • Aug 2013
                      • 1221
                      #370
                      Maybe, but the project is so slow at the moment so everyone that reads it will fall asleep :D
                      No, Jaguar :)
                      Ok, then the E34ix hubs must be a little wider because theese rotors are 3mm shorter than M3 E36 :)
                      Sorry for the slightly over sized picture btw haha :D
                        • Jun 2010
                        • 2796
                        #371
                        What year & model Jaguar?
                        • Nisse Järnet
                          • Aug 2013
                          • 1221
                          #372
                          XK 8 Coupe (QEV) 03/96 - 12/06 and XJ (NAW, NBW) 07/97 - 05/03
                            • Jun 2010
                            • 2796
                            #373
                            Thanks!
                            That will be really handy info for figuring out a bolt-together 5-lug swap. Those are your E34 hubs, right?
                            • Nisse Järnet
                              • Aug 2013
                              • 1221
                              #374
                              Thanks!
                              Nope, E87 :)
                                • Jun 2010
                                • 2796
                                #375
                                Nope, E87 :)
                                Good to know!
