24V AWD Swap Knowledge Base
This is a sticky topic.
  • The Dark Side of Will
    • Jun 2010
    • 2796
    #871
    Originally posted by Bimmer_man
    It is absolutely astonishing how much knowledge there is between you two nando and will.
    We've just done a lot of things wrong.
    Originally posted by Nisse Järnet
    Are you sure about this? I thought the E46 outer CVs had bigger splines?
    Originally posted by nando
    yeah I'm pretty sure the E46 doesn't fit the E30 at all. Flybox was the one who tried that.
    Ooops... I guess I didn't clarify that very well. I meant the splines where the shafts engage the CV joints... not where the CV joints engage the hubs. I *THOUGHT* all the BMW front drive hardware was the same at that location, but I may not be remembering earlier content in this thread correctly.
    • Nisse Järnet
      • Aug 2013
      • 1221
      #872
      At least the E34 and E30 is different at that point :)
      E30 325ix M50 turbo 7 spd DCT 4wd 840awhp @ 31 psi.
      E30 M50 6 spd 764whp @ 24psi.
      E30 M20 6 spd 675whp.
        • Jun 2010
        • 2796
        #873
        Ok, I'm going to have to go back through the 59 pages of this thread to figure out what interchanges with what...
        • flyboyx
          • 8371
          #874
          having taken apart an e46 axle side by side with an e30 axle (and e34)and hoping for this same good fortune, i can say for a fact that they are not even close.
          Gigitty Gigitty!!!!
          • Nisse Järnet
            • Aug 2013
            • 1221
            #875
            Just a little teaser :D
            • Nisse Järnet
              • Aug 2013
              • 1221
              #876
              Also did some more software tuning, now the tc locks at different set boost levels on each gear :) And it stays open all the time in 5th gear, no lock needed in 5th.
                • Jun 2010
                • 2796
                #877
                I guess I just need to go review...
                • stonea
                  • 2892
                  #878
                  I think the e46 and e53 might have been the same. I know something was the same.
                  Sent from my SM-G920V using Tapatalk
                  My Garage
                  Feedback
                  Instagram: Stone.Hopkins
                  • AndrewBird
                    The Mad Scientist
                    • 11897
                    #879
                    Bumping this because I am replacing the clutch in my E34 IX and will have all the drivetrain out tomorrow (including engine). Anyone need/want pictures or measurements of anything? It's all going back together Saturday, so make your requests now!
                      • Jun 2010
                      • 2796
                      #880
                      Just take a video :-P
                      • Bimmer_man
                        • Jan 2013
                        • 1477
                        #881
                        Need a little advice. So I'm looking at redoing my front half shafts again .........yay, and with me upgrading to the 525ix drivline. Are the e30 half shafts used or are they 525ix only?
                        Float like a cadillac sting like a Bimmer!:)
                        • stonea
                          • 2892
                          #882
                          I think Nisse used 525ix half shafts, but had no machine the ousides or something. I'm probably going to go custom and do x5 inners and e30 outers.
                          My Garage
                          Feedback
                          • nomansland92
                            • 1657
                            #883
                            You need 525ix half shafts with the 525ix diff
                            IX being restored here
                            Ix turbo build here
                            • stonea
                              • 2892
                              #884
                              So while looking for someone to rebuild my front CV's I found this place.
                              They say they'll do custom axles. I'm sure its not cheap, but its an option.
                              My Garage
                              Feedback
                              • flyboyx
                                • 8371
                                #885
                                this find potentially has a lot of value. thank you for posting this.
                                Gigitty Gigitty!!!!
