Originally posted by nando
View Post
24V AWD Swap Knowledge Base
This is a sticky topic.
My Garage
Feedback
Instagram: Stone.Hopkins
Originally posted by stonea View PostDoes anyone happen to know if the internals of a e30 M3 rack fit in a ix rack? I'm sure no one does and I kind of doubt it would work. If it did, I know the cost vs benefit wouldn't equal out, but I've just been thinking about it recently.Originally posted by nando View PostWon't work - they are completely different.
We know the housings and mounts are different, just wondering about the rack gear and pinion itself.
the inner pulls off as i recall. it has those three little bearing wheels. i think i remember the outer having a circlip that goes the opposite way the e30's axle does?sigpic
Gigitty Gigitty!!!!
Originally posted by Sebbe View PostDoes anyone know if the E30 outer ball joint will fit the E34? They look very similar and the locking nut is m14x1.5 on both cars. One of the outer ball joints on my 525ix is bad, and i really dont want to spend 300$ on a replacement control arm.E30 325ix M50 turbo 7 spd DCT 4wd 840awhp @ 31 psi.
E30 M50 6 spd 764whp @ 24psi.
E30 M20 6 spd 675whp.
more than likely, an e34 rwd or e36 ball joint would be more correct than an e30's.Last edited by flyboyx; 07-20-2016, 06:00 AM.sigpic
Gigitty Gigitty!!!!
that's true, but remember, on newer cars BMW broke out individual part #s for less and less assemblies. A good example would be the differentials. You could (before it all went NLA) get every nut, bolt, washer and bearing individually for an E30 diff, but on a newer car, you can only order the entire diff. on the E34 ix, BMW didn't break down the transfercase, so the individual parts are not replaceable.
There is no OEM replacement ball joints for either the E30 or E34, only the whole control arm, a couple of aftermarket companies sell ball joints for the E30, but not E34. E36 ball joints doesnt fit, they are M12, RWD E34 ball joints are M14 so they might fit, but i can only find complete control arms.
I dont think BMW made a special ball joint for the 8000 or so 525ix's they sold. So in guessing its either a 325ix ball joint or RWD E34.
