Need to make a decision. Need some help.
    • 34835
    #46
    I have a brand new TC. if we can come up with a standard test that anyone could do, I could test mine as a baseline.
    • flyboyx
      • 8371
      #47
      man, thats a great idea. it would be so awesome to know what torque value it will take to break it loose.
      do you have an extra front drive shaft?
      Gigitty Gigitty!!!!
        • 34835
        #48
        yes. two, actually. Yeah, I have a problem..
        • 6A LDY
          • Jul 2014
          • 317
          #49
          what if you took the rear section (u-joint, past the slip yoke) and inserted that and made some sort of bracket to mount to the four bolts of the u joint or just weld on a socket?
          I dont know if the shafts are the same size or not, but you could get a crappy old shaft for free or close to it probably.
          1988 325iX - sold but not forgotten
          1984 MTech1 323i
          • barbierij
            • Sep 2012
            • 1294
            #50
            Originally posted by flyboyx
            in fact, why don't you put a torque wrench on one lug nut while you have your one front wheel jacked up? obviously, it won't be centered on the wheel and this will somewhat skew a scientific result, but you will have 2 values under the same conditions to compare.
            that would over-torque that one lug bolt or even snap it. if anything, you could use the axle nut since it should be around 200ft lbs anyway.
            FS NY: two Audiobahn A235HC amps and audiobahn 1farad capacitor
            Saab/GM tech2 programming
            My for sale thread
            1990 325iX for sale or part out
            Did you buy something from me? Please leave feedback!
            Originally posted by K20RI_211
            And I have to ask if you make a hobby out of thread-bombing with retarded questions?
            • flyboyx
              • 8371
              #51
              i agree that this would certainly be a better location but i seem to remember there being a piece of sheetmetal that locks the nut in the axle. i was thinking it might be in the way. also, if he can spin it by hand without too much trouble, it probably won't be an issue for the lug nuts. most people probably won't have the right socket to fit that nut in the middle of the hub since it isn't a common size.
              it has been a long time since i messed with this. i'll put some more thought into it
              Gigitty Gigitty!!!!
                • 34835
                #52
                I'm pretty sure the torque that it takes to slip the VC is waaaay less than what it would take to snap a lug bolt. one lug bolt probably has 50,000psi or more of shear strength.. you're not going to shear that with a torque wrench. :p
                • flyboyx
                  • 8371
                  #53
                  i played around with my ix parts this morning. i made a new thread on doing this test.
                  Gigitty Gigitty!!!!
                  • Alaska Ted
                    • Apr 2015
                    • 145
                    #54
                    t-case test
                    Nice work! I'll give it a try
