Official 325ix ride height thread
This is a sticky topic.
    • 34839
    Post pictures & specs here!
    Ride height will be defined as measured from the center of the wheel/hub to the bottom edge of the fender lips.
    Please post in the following format:
    Year: 1991
    Miles: ~265,000
    Springs: Ground Control 450/600
    Struts/Shocks: Koni Race
    Front Height: 11 3/4"
    Rear height: 11"
    Other Notes:
    The strut housings have been shortened by 2", which allows for greater travel. Neither the front or rear perches are at the bottom, but much lower isn't really possible as the CV shafts are at an extreme angle and there's limited space between them and the frame rails.
    AFAIK the front height of a stock ix is over 14", depending on what pads & springs BMW used. Earlier ix's were also heavier, my 10/1990 for example came without trunk tar from the factory, but on my 9/87 ix it was about 1" thick. So the same suspension could settle differently depending on when the car was built.
    • 34839
    I don't have height measurements, but here's the H&R suspension back in 2004:
    • fresh_TD
      • Aug 2013
      • 2457
      -Year: 1989
      -Miles: 103,000
      -Springs: Suspension Technique ix Springs
      -Struts/Shocks: Bilstein Sport
      -Front Height: 12.6"
      -Rear Height: 12"
      20150702_054511 by Manny Nieves, on Flickr
      '91 318i (Alpine) - daily
      '88 325ix (Zinno) - drive here and there!
      • flyboyx
        • 8371
        chris, what are you using for upper strut mounts and control arm bushings?
        Gigitty Gigitty!!!!
          • 34839
          Ground control camber plates, E30 M3 offset CABs.
          • Northern
            I like cupcakes & sh!tboxes
            • 5231
            Tire size would also be good to list, since that could skew results (people running 205/50 instead of 205/55, or people with 17's and plus size diameters, etc.)
            EDIT: Nevermind, misread the measurement, thought we were measuring from the ground...
            I guess some stock-ish comparison is good?
            Year: 1987
            Miles: ~160k
            Springs: OEM iX
            Struts/Shocks: Bilstein HD
            Front Height: 16"
            Rear height: 16.5"
            Originally posted by priapism
            Originally posted by shameson
              • 34839
              Yeah, tire size won't matter because youre measuring to the center of the wheel, not the ground.
              Do you have extra spring pads or something?
              • fresh_TD
                • Aug 2013
                • 2457
                16" R / 16.5" R seems higher then stock height
                Sent from my Samsung Note 4
                  • 34839
                  It looks like an early body ix so it could be right. Or maybe because the flares are missing.
                  • Northern
                    • 5231
                    It is an early iX, and yeah one of the PO's removed the flares and filled all the holes in the wheel arches. I wouldn't be surprised if it is higher than stock though...
                    No options (other than a custom/special colour of some kind, dark metallic greenish blue. Someone painted the exterior DS unfortunately.)
                    So, no sunroof, comfort seats, no A/C, no premium sound.
                    Carpet is now gone, seats are some FIA expired takeoffs from a local stage rally car, nothing in the trunk, and it's well underway a rigorous rust-based weight savings plan.
                    Also as it sits, there are no fluids in the engine, no exhaust/rad. Does have a manifold, HX35/40 and associated oil lines/filter relocation/charge piping.
                    Hopefully some of that will be resolved this fall.
                    • Nisse Järnet
                      • Aug 2013
                      • 1221
                      Year: 1989
                      Miles: ~150k
                      Springs: Ground Control 450/650
                      Front Height: ~12"
                      Rear height: ~12"
                      M3 E36 offset CABs, GC Camber plates up front and adjustable toe/camber in the rear.
                      E30 325ix M50 turbo 7 spd DCT 4wd 840awhp @ 31 psi.
                      E30 M50 6 spd 764whp @ 24psi.
                      E30 M20 6 spd 675whp.
                      • mtnbimmer
                        • May 2012
                        • 73
                        Year: 1989
                        Miles: 292,000
                        Springs: Lowtec 05370F
                        Front Height: 30 cm (11.8")
                        Rear height: 28 cm (11.0")
                        M3 offset CAB's
                        • stonea
                          • 2892
                          Year: 1988
                          Miles: ~230k
                          Springs: OEM ix
                          Front Height: 14 3/4 inches
                          Rear Height: 13 1/4 inches
                          My Garage
                          Feedback
                          Instagram: Stone.Hopkins
                          • ak-
                            • 12422
                            Other Notes:
                            Seeing how you sectioned the strut housings by 2", what Koni Race insert did you use to compensate? Not stock spec'd iX Koni Race shock, right?
                            Would you happen to know the rod length and shaft travel of the shock you used or a part # so i can look up the specs Nando?
                            1991 325iS turbo
                            • Nisse Järnet
                              • Aug 2013
                              • 1221
                              I'm using the same thing: Koni race inserts ( P/N: 8610-1436race)
                              Don't forget: Koni glad nuts ( 73.25.01.003.1 (M48 x 1.50))
                              They are great! :)
