Tie Rod replacement
  • Kershaw
    • 11822
    Tie Rod replacement
    The only time I did this I was swapping the whole rack so I dropped the front subframe. Can the inners be replaced with the subframe still on the car?
    AWD > RWD
    Yes. You will want new boots, clamps, and lock rings.
    • uturn
      • Dec 2010
      • 1001
      The inner tie-rod takes a big wrench also but if you don't care about the finish can put a pipe wrench on it.
      • 101
        • Jul 2011
        • 764
        ^^^ I think OP has an IX. I haven't tried tie rod replacement on mine, but it looks a heck of a lot tougher to get at vs. a 2WD car.
        101
        The E30 collection:
        1987 325es M52 - Schwarz / Taurus Red Sport (son #2's)
        1987 325is - Delphin / Black Sport (son #3's)
        1987 325i Convertible - Triple Black
        1989 325iX Coupe - Diamondschwarz / Black Comfort
        1990 325iX Coupe - Sterling Silver / Grey Sport
        1981 Fiat 124 Spider 2000 - Green / Tan
        1998 Volvo V70 GLT - White / Tan
        1998 Volvo S70 T5 manual - White / Taupe
        2001 Ford Windstar - Silver / Grey (parts hauler)
        2006 Lexus GX470 - White / Tan (tow rig)
          • 34839
          it's not that bad. actually, I don't know what would even be hard about it. they're right in front of the struts. I don't think you can do the inners without doing the outters though - that is, I've never seen them for sale separately.
          basically you just turn the wheel all the way to one side, then you can easily get at the lock plates etc. I'd lay them on the ground and try to match the lengths, then when you have it aligned it will be close enough to drive it to the shop.
          • downforce22
            • Aug 2009
            • 3192
            This thread is relevant to me as I need to do this on my car. Was wondering how to break the inner section loose.
              • 34839
              you just pry off the lock clips and use an open end wrench on the inner tie rod. the boot has to be cut off, of course. it's not hard at all.
              • Kershaw
                • 11822
                That's exactly the advice I was looking for. I did not even think to turn the wheel side to side. And yeah, they're only sold as a set, but replacing the outer is obvious it was the inner where I was like, "ffs, I do not want to drop the subframe."
                AWD > RWD
                • monticello
                  • Sep 2007
                  • 202
                  I've never done inner tie rod ends on an IX, but I have on other cars. There's an inner tie rod tool for the job.
                  • Z3C Tblau
                    • Feb 2022
                    • 9
                    Thanks for the advice and reassuring words :)
                    Quick word of caution :
                    Quite easy job, true, except for putting back the inner boot clamps : poor access means no way to use a crimping tool so I resorted to screw clamps that will do the job but wouldn't stay in place and were a bit of a pain to install...
                    Also, passenger side inner was quite difficult to unscrew as the wrench would have had to be horizontal which isn't possible given there's a control arm, half-shaft and sway bar in the way... Had to grind some, so as to put the wrench on vertically. Should have tried a pipe wrench...
