Control Arm Price Hike?
  • 4x4_e30
    • Sep 2013
    • 164
    About 6 months ago I was looking around for a control arm, found a couple for $180. I cant remember if they were genuine BMW or not. But everywhere I look now they're $300+. Was that previous price for Lemforders, and they stopped making them?
    My plan was to buy one brand new and use one of the FARO arms at work to reverse engineer it and make something like the SLR tubular arms (without that high angle cantilever dealio). That's starting to look like my only option now, since I own 2 iX's and control arms are the kind of thing that need replacement every couple years.
    Which gets me thinking, at that price point I could start selling them... Anyone interested in some tubular control arms? I could make some that accept the factory ball joints or a set that uses spherical bearings...
    Also, does anyone know the difference between the 2WD and AWD control arms?
  • Kershaw
    • 11822
    You can replace the balljoints.
    AWD > RWD
    • 4x4_e30
      • Sep 2013
      • 164
      Sure, when it's not folded like a taco. Junkyard iX, ftw.
      • TimeMachinE30
        • Jun 2014
        • 3749
        Fcp Euro. I just replaced the set. Meyle for under 180 shipped.
        https://www.fcpeuro.com/products/bmw...0-e302piece-my
        Edit: my bad iX. No wonder Kershaw was here.
        ACS S3 Build / Dinan 5 E34
          • 34839
          this is why I hoard old ix arms.. the only problem is, I don't have ball joints for them, lol.
          last time I replaced them, it was still about the same price to get a whole new arm, but now it sounds like I should find a couple sets of ball joints. Unfortunately, as time marches on getting parts will continue to get harder. it's still not bad, but damn, the '88 ix is almost 30 years old now..
          • TehRaydarlover
            • Mar 2013
            • 544
            Are the Lemforders inner ball joints available anymore? I have a few worn-out sets of control arms that I was planning on rebuilding but when I was looking back in the fall I couldn't find any anywhere. This is the part number I was using: 31 12 1 701 063
            Build Thread
            Rear Diff Rebuild
            Rebuildable Viscous Coupling
            Transfer Case Rebuild
            "Life is simpler with 12 valves"
            • packratbimmer
              • Dec 2009
              • 1330
              I still have a pair. They are not beautiful, but the balls still have a lot of life left and the boots are good. Make an offer for the pair.
                • 34839
                The inners seem to last about 4x longer than the outters. at least, on all the control arms I have, the inners are still good.
                • TehRaydarlover
                  • Mar 2013
                  • 544
                  Huh, I've had like the exact opposite experience, both times I've had to do the control arms its been the inner ball joints that have worn out. On two different cars that is. Weird haha.
                  Build Thread
                  Rear Diff Rebuild
                  • AndrewBird
                    The Mad Scientist
                    • 11898
                    I really wish ball joint manufacturers would list cross reference data. There has to be other cars that use the same size/dimension ball joints, but you would never know because the part number is based off what car it goes in, not what size it is. Same for wheel bearings and many other parts.
                    • stonea
                      • 2892
                      ^This. It would be great if you could search dimensions instead of part numbers.
                      My Garage
                      Feedback
                      Instagram: Stone.Hopkins
                      • Kershaw
                        • 11822
                        You can order them from NAPA, Lemforders, I think I have 2x inner and outers sitting in my basement.
                        I think it's $60 a side. Better than $220.
                        AWD > RWD
