FI vs stroker
  • ACVC325ix
    • Dec 2016
    • 123
    FI vs stroker
    So I've been going thru the IX threads for a while now and I was hoping to start a thread to get a definitive answer as to which is the overall better route to go for more power in our IX's: Forced induction or 2.7/2.8 stroker?
    I've been turned off of engine swaps due to the extensive fabrication needs the IX's have over its other E30 brethren....I read thru the thread by 6A LDY and it still seems that there are additional fab requirements for the bottom end due to different positions unique to the IX.
    So if I want to be in the mid 200's BHP, is turbo'ing the M20B25 stock engine truely the best way to go for the $$$$?
    Thanks in advance yall!
    :p:p:p:p
  • stonea
    • 2892
    FI is basically always going to be the best bang for your buck. However I think FI to just get into the mid 200's is a waste. I'd do a high compression 2.8 with supporting mods and settle for what you get. I'm guessing around 220 hp, but I'm not a expert.
    My Garage
    Feedback
    Instagram: Stone.Hopkins
    • Nisse Järnet
      • Aug 2013
      • 1221
      Stroker AND FI :D
      E30 325ix M50 turbo 7 spd DCT 4wd 840awhp @ 31 psi.
      E30 M50 6 spd 764whp @ 24psi.
      E30 M20 6 spd 675whp.
      • berlow94
        • Jan 2013
        • 1063
        The reason that i have just as much fun in my mostly bone stock IX as my fully gutted track car is because of driveability.
        I have never experienced a turbocharged engine that had the same torque/power curve as a properly built N/A motor.
        At the end of the day, it comes down to your specific goals. Are you looking for more power everywhere under the curve? Or is the bottom end fine for you and you just want to do 170mph on the highway?
        My vote goes for stroker and keeping the motor N/A.
        The best one-stop shopping for German car parts and lifestyle: http://www.gutenparts.com/
        • The Dark Side of Will
          • Jun 2010
          • 2796
          Don't waste time with a 2.7/2.8... go to 3.0.
          Also, you'll need a good bit of head work and a fairly aggressive cam to hit 250 hp.
          • ACVC325ix
            • Dec 2016
            • 123
            Def looking for power throughout the curve, also want to be able to drive from point A to point B without worrying about breaking something or going through an entire tank of gas lol. The more I learn the more NA seems like its for me...
            Still tho, does stroking the M20 in the IX really cost that much more/need a lot of drive train fab?
            cheers!
              • 34839
              Stroking an ix engine is exactly the same as any other M20. You just need to start from an ix block.
              • stonea
                • 2892
                If you're buying pistons then yeah just go with a 3.0, but by using early model 325i pistons and shaving the skirts you can get a 10.*:1 compression ratio on 2.7 and 2.8 strokers.
                My Garage
                Feedback
                • ACVC325ix
                  • Dec 2016
                  • 123
                  Awesome, thanks y'all!
                  • ThatM20Guy
                    • Aug 2014
                    • 600
                    Would it be possible to shave like 20 thou off the head or block to get it even higher compression? From what i'm looking at all that would be needed to make a 2.8 would be an m52 crank, stock b25 pistons and 130mm rods from an eta?
                    89' 325ix Diamantschwarz/Black rattle can...
                    Insta: r_moose_w
                    Originally posted by flyboyx
                    I imagine her smelling like spoiled milk and having a half inch crust of doodoo circumnavigating her butthole.
                    • Nisse Järnet
                      • Aug 2013
                      • 1221
                      Well, if you take that properly built NA motor and slap a good sized turbo on it, it will just be even better :)
                      • berlow94
                        • Jan 2013
                        • 1063
                        I disagree with this.
                        A properly built high output NA motor will use completely different parts than a properly built high output boosted motor.
                          • Jun 2010
                          • 2796
                          What beyond compressio ratio and cam specs would be different?
                          • downforce22
                            • Aug 2009
                            • 3192
                            if you are paying for custom pistons, why not go as big as possible? The m20 with 135 mm rods and 89.6 crank has the same dimensions as the s52b32(us) so with quality components, no reason not to rev it out to 6000 rpm.
                            Turbos are fun and addictive, so are strokers. I like the screaming high rpm power delivery of the s38 but with aggressive cams it doesn't have that power on the bottom end so it isn't much fun to drive when you can't open it up without significantly exceeding the speedlimit. You can atleast size the turbo and plan the engine well enough that when you accelerate up to speed you get that boost kick and turbo noises without having to drive ridiculously fast.
                            • Wolfman
                              • 341
                              I'd call an S54 a properly built high output NA motor and look what they're capable of boosted- even with all stock internals!!!
