So after installing supposedly rebuilt engine it turned out to be not so good. Got oil in my coolant tank after the first start up. What are my options? I have my original complete engine with a head. Should I remove that and rebuild it or try to find a rebuilt one? Anyone can suggest a reasonable machine shop who can do the job? I'm in Sacramento CA. Also what new parts will I need for the rebuild? It was supposed to be a small restoration project for my wife but I'm $14k into it already and the car still doesn't run.
Blown head gasket need advice 89 325ix
I would start by doing some diagnostics on the new engine.2006 GMC Sierra 2500HD 4WD LBZ/Allison
2002 BMW M3 Alpinweiß/Black
1999 323i GTS2 Alpinweiß
1995 M3 Dakargelb/Black - S50B32/S6S420G/3.91
1990 325is Brilliantrot/Tan
1989 M3 Alpinweiß/Black
sigpicComment
I'd rebuild the original. also, the 885 head was used on both 2.5 and 2.7 liter engines, that's normal.Comment
I thought you bought a "rebuilt" engine and that didn't work out? I meant rebuild the motor that originally came from your car. Unless the gasket is totally screwed on that "rebuild" you have, coolant/oil mix means something is likely cracked (head or block).Comment
Rebuild the best bottom end. A head gasket is not a horrible job on an m20 I wish you were on the east coast I would be happy to take that on. If you are already that deep into it then take your original head to a reputable machine shop have it decked and tested.
Sent from my iPhone using TapatalkComment
I had one that was mixing oil and coolant, turned out to be a cracked head in the cam journals. I put a used head on it, no problems. Not that long ago, I replaced the head on my current car with a bimmerheads rebuilt. I've had zero problems with it.Comment
Yep.
I had this as well. Bottom end was fine. It just needed a new head.AWD > RWDComment
If there's coolant in the oil, the head is cracked. The m20 has no place where the oil/coolant can mix with a blown head gasket alone.
Instead, the cam valley cracks and when pressurized, the coolant passes through the crack and mixes with the oil.
EDIT:
I read your replay in full after posting. You would be correct, sir.Comment
Thanks for the advice! I will look into rebuilding my old head. It's not OEM as mentioned but it worked before.If there's coolant in the oil, the head is cracked. The m20 has no place where the oil/coolant can mix with a blown head gasket alone.
EDIT:
