Driver side axle
  • CPTFelch
    • Dec 2014
    • 124
    Driver side axle
    the threads on mine were summarily destroyed while removing a seized axle nut and the whole stub end is ruined. Trying to track down one decent one or if it needs rebuilding it’s fjne as I’ve got the others at axles Unlimited in NC currently.
    Appreciate any leads
    sigpic15 year old me is super impressed with real me
  • Kershaw
    • 11822
    Next time, leave the nut on there while hammering on it. Or better yet, use an air chisel with a pointy bit and set that in the hole at the end of the axle.
    If you find a destroyed parts axle, you can disassemble the cv joints on both axles and build one good one.
    AWD > RWD
      • 34844
      I use a hub puller to press mine out. I would never use a hammer on an axle that costs $1200 new. That's an unfortunate lesson. :(
      Before I got new hubs, I could push them out with my finger (because I had lubed them and done it so many times). The new hubs weren't machined as nicely so I have to press them off again.
      • CPTFelch
        • Dec 2014
        • 124
        Yeah no hammer was used on the actual shaft. Unfortunately the axle nut couldn’t be lodged loose despite days of pb blaster, heat, notching the bolt and hitting it with an air hammer/chisel. When the nut finally split the threads on the end had been so damaged that I couldn’t chase them and wouldn’t feel comfortable using it again. I can keep it as spare parts but that’s about it.
        • rwtags
          • Aug 2018
          • 208
          Take a picture of the threads, if it's just in one spot, just chase the threads and drill a hole through it and put a cotterpin through it. Can't mess it up anymore than it is?
            • 34844
            I've never even bothered to use those stupid lock plates on the front axles, and I've had an ix for a long damn time (and beat the crap out of it on the track). Yeah, I think it'd have to be pretty badly damaged to be totally unusable.
            I mean really. I have to stand on the breaker bar to torque the thing enough so the bearing doesn't fall apart (well, maybe not anymore - I'm old and fat now). Anything past that is gravy. It's not going to come off on it's own - ever.
            I have a saying now, 'gutentite'. Unless it's TTY (stretch bolts), it really doesn't matter too much. Even buildings and critical infrastructure in high seismic areas only get bolted together by feel - 'snug tight', per the engineers. For real. And most of the iron workers out there bolting shit together are idiots. So don't worry so much about it on a $3000 car....
            • AWDBOB
              hooptie connoisseur
              • Aug 2013
              • 4490
              I actually think I have an outer joint, let me check.
              Untitled by Bobbie Morrone, on Flickr
              • rwtags
                • Aug 2018
                • 208
                damn this guy is coming through! still think a cotterpin and a castle nut will do you well!
                • The Dark Side of Will
                  • Jun 2010
                  • 2796
                  Do you know what a thread file is?
                  Google it... it may save the part.
                  What's size are those threads?
                  • CPTFelch
                    • Dec 2014
                    • 124
                    Yeah the stub end wa so retry toast. Luckily found a spare axle local here so rebuild is back underway. Though might need a spare just to keep it around.
                    Nando - good to know about the locking plates.
                    Yep familiar with all the ways to correct the threads. Though drilling and running a castle nut and cotter pin is not a bad idea.
                    • Kershaw
                      • 11822
                      I never put the locking plates in on my rallycross ix either and that car has seen some abuse.
                      AWD > RWD
                        • 34844
                        I wish you could "like" posts here, lol
                        • RWD BLOWS
                          • Nov 2018
                          • 85
                          Really though! Its 2019 these forums need to catch up with Instagram and Facebook haha
                          • Kershaw
                            • 11822
                            There isn't a reputation functionality built in to vBulletin? That's halfway there.
                            AWD > RWD
                            • agent
                              Vice Grand Pubaa
                              • 7960
                              I'm happy we don't employ any of that functionality. Liking a post has absolutely zero value other than inflating the ego of whoever authored it.
                              It's a message board, not a popularity contest. Also, get off my damned lawn!
                              Originally posted by kronus
