I'm used to regular e30z, .. e-brake?
  • ethirtydavid
    • Jan 2008
    • 2331
    I don't pull the e-brake a lot anymore when I drive like I used to when I started trying to figure out my first e30. There are some instances, however, where an e-brake can be very beneficial - is it ok to pull this thing on an IX?
    Where does it put stress? the transfer case?
    Thanks guys. I know people pull e-brake a ton for WRC so.. ......
  • ethirtydavid
    • Jan 2008
    • 2331
    Anyone?
    • moatilliatta
      • 6150
      Ive been temped to do mine. i guess as long as it for a short time it might be ok. just enough to do a 180. i mean wheels spin all the time... esp in snow... Im prolly not right on this. im just trying to make it sound ok so i can feel ok doing it..
      @Zakspeed_US
      • ethirtydavid
        • Jan 2008
        • 2331
        when I use the e brake it's instantaneous. up-down. just enough to move the weight a little more. The issue isn't with wheel spin - it's the surge through the drive train caused by locking half the system (rear end) that I am concerned about.
        anywaysthasknaa
          • 34839
          it's not going to work, the front and rear wheels of the ix are locked together, so pulling the ebrake is like locking the brakes on all 4 wheels. it will also stress your transfercase because that's what locks them together.
          • moatilliatta
            • 6150
            i figured the viscus would slip at least some.
            @Zakspeed_US
            • Dominic49
              • Feb 2007
              • 1373
              your supposed to put the clutch in when yo pull the ebrake retards....
              • ethirtydavid
                • Jan 2008
                • 2331
                clutch in or out, the stress is still on the transfer case though ..
                • supernaughtIX
                  • Apr 2007
                  • 260
                  with IXes, stick to using that for parking and emergencies.
                  88 325 IX DiamantSchwarz - TOURING - waiting...
                  89 325 IX AlpinWeiß - Gone
                  88 325 IX DiamantSchwarz - Parted
                  89 325 IX RoyalBlau - Parted
                  88 325 IX RoyalBlau - Gone
                    • 34839
                    the clutch doesn't disengage the VC, but maybe you didn't realize what forum you're in. ;)
                    using the ebrake for any extended period of time or multiple times will burn out your transfercase. and it won't help you turn the car at all anyway, so do not do it, ever.
                    • Autobahn Sport
                      • Apr 2008
                      • 411
                      Transfer cases are not-be-cheap, and they are far from bulletproof. Make sure you are a baller before you start doing e-slides.
                      Autobahn Sport - ***503.715.0044*** - "ABS BMW Parts" on AIM
                      **To avoid delays with shipments, please note which parts you are paying for AND YOUR R3VLIMITED USERNAME in the "note to seller" field when using PayPal**
