What to do? Megasquirt and ix (c101:17 to ECU:50) engine braking torque reduction?
  • ForcedFirebird
    • Feb 2007
    • 8300
    From what I can gather, pin #17 in the c101 is unique to the ix, and is some sort of signal for the ECU/ABS to communicate. Maybe so if a tire is not spinning during acceleration, the ABS won't energize (only energizes if the decel sensor is reading deceleration).
    That being said, what has everyone doing for this circuit with MS?
    john@m20guru.com
    Links:
  • Eskie
    • Dec 2014
    • 162
    I grounded it with a 1k resistor per this post from e30zone. I haven't noticed any negative effects...
    https://www.e30zone.net/e30wiki/inde...rting_Your_M20
    • ForcedFirebird
      • Feb 2007
      • 8300
      Thanks! Didn't think it was that simple.
      john@m20guru.com
      Links:
        • 34847
        yeah, this was solved ages ago. It's actually the same fix they used on early 88's that had faulty DMEs.
        I tried building a circuit that would enable it again, controlled with the input from the mercury switch and a signal from Megasquirt to the ABS computer, but I never really got it working - mostly I just stopped caring because I have never noticed an issue anyway. All it does is prevent you from locking the brakes if you lift off the gas too quickly on low friction surfaces, but I am much more careful with my throttle than that, and use the transmission appropriately when slowing down.
        On Motronic there's a second ICV circuit (even on non-ix DMEs, which aren't really a thing) that just isn't connected to anything on regular E30s. The on/off output from the mercury switch can trigger an on/off output from the ABS to pin 50 on the DME to open the ICV in case of wheel lockup during engine braking. This is also why the IX has an extra clutch switch - one for ABS, the other for cruise control.
          • 34847
          I should have clicked that link first. I couldn't remember the link to my own guide. :p
          Lots of other info here:
          I'm glad I documented everything though because if it broke, I have absolutely no memory of how any of this stuff works. Funny thing is I haven't had a single Megasquirt related failure in 14 years..
          • bradnic
            • Jul 2012
            • 3554
            nando that's one helluva endorsement for MS. thanks
            HOWTOs:
            DB vert plastic bumpers
            OEM Keys
            MTech1 docs
            88 ix Lach/Card
            91 ic Calypso 3.1
            86 Cosmo 2.7
            OEM+ or bust!
            • ForcedFirebird
              • Feb 2007
              • 8300
              Yeah, Chris has been a great resource for many of us over the years. :)
              john@m20guru.com
              Links:
              • Eskie
                • Dec 2014
                • 162
                Awesome info Chris per usual!!
                • packratbimmer
                  • Dec 2009
                  • 1335
                  Sticky!
