3 eyed e30s
  • russiane30
    • Dec 2008
    • 46
    3 eyed e30s
    Post some pics up of your velocity stack setups!
  • korea619
    • Aug 2009
    • 39
    M20B25 leave me on the straights ill take you on the turns
      • 34839
      it works too - 60% reduction in intake temps at low speed (20-35mph) and about 25% at high speed (50-100mph). It doesn't increase intake pressure though.
      • 87e30
        • Jul 2008
        • 5676
        Not to totally distract... but why does everyone say that these are stupid? I like it, keep 'em coming.
        I just hate everyone.
        No need for discretion.
        • Van Westervelt
          • 9365
            • 34839
            not much point on a street car
            they also seem to work better on cars with smoked front ends. you can barely tell that I'm missing a high beam, but on a car with clear lights it would stand out quite a bit.
            plus a lot of general BS about what it does. It's very functional at reducing intake temps. Not great at producing any pressure.
            • Disaster Inc
              • Oct 2007
              • 429
              and would make it impossible to pass the yearly rmv inspection here...
              • erik325i
                • Jan 2005
                • 3567
                • mcr_driver
                  • 4491
                  is that an oem csl intake manifold? if soo i think i need to start fapping...
                  • SA E30
                    • 1248
                    Doesn't look oem CSL isn't 2 piece and doesn't say BMW M Power on it.
                    Still is totally worth fapping over!
                    • wolfgangstbd
                      • 960
                      anyone ever think of using a intake velocity stack? there O.D. is 6" on average tho. they are legit aluminum in like any color. i think it could make a good fit
                      • fiftytakedowns
                        • 2460
                        Can someone Post on how they did it with their US ellipisoids , or how they attached the Stack to the Bracket, ETC.
                        Where to get the stack, how to adapt the US ellip bracket.
                        [/url]
                        Team USA Wrestling 67KG
                        • fiftytakedowns
                          • 2460
                          This was with my sealed beams
                          [/url]
                          • fiftytakedowns
                            • 2460
                            If you were to do a Hose Directly to the headlight (bracket) from the airbox
                            I'm pretty sure it would do something. I wonder if you could do a straight shot, or turn the airbox on it's side so the air goes through large hose directly through the filter into the afm, almost like the air is hitting a wall (filter), instead of going to the bottom of the airbox, up through the filter, and then up again into the Afm. I hope i'm making sense, but I seems like it would work to create a minimum amount of pressure.
                            [/url]
                            • Drew325is
                              • Oct 2004
                              • 520
                              Originally posted by korea619
                              Korea619, details of the stack you've used there?
