IS Side skirt jig/template
This is a sticky topic.
  • bernzpeed
    • 3917
    does anyone know where i can get one? I have a brand new set of IS Side skirts but do not have the jig or template to drill holes in. If someone can direct me to the right person, I would really really appreciate it.
    89 E30 S52
    Transaction Feedback.
  • TurboJake
    • 3780
    Wait...
    What?
    Drill holes where?
    Leave Me Transaction Feedback
    • TexasTerp
      • Jan 2009
      • 3541
      there isn't a good one available. You pretty much have to make your own from what I remember. I haven't met anyone that has used an oem template for them yet.
      stephenbrody.com
      • ak-
        • 12422
        My car luckily came with IS skirts and have the holes pre-drilled. I'm selling the skirts, so maybe I'll make an outline of them for r3v asshat's to use soon
        <3
        If drilling ain't your thing, you can use the factory clips at the bottom, which hold pretty well, and thin double sided tape for the top.
        1991 325iS turbo
        • bernzpeed
          • 3917
          <3
          I want to drill. It's more sturdy that way. I would appreciate it if you could make a template for me. Thanks in advance.
          89 E30 S52
          • Garageaholic
            Freestyle Fabricator
            • Dec 2005
            • 5204
            I have some too and haven't installed yet. I was going to quintuple check my dimensions before drilling anything.
            Of course, a template would greatly assist me in my efforts. Thanks!!!
            Recent Rebranding!!
            E30 SM62/S62
            E30 M60 V8
            E30 M30 Big 6!
            Instagram.com/garageaholic
            Youtube.com/garageaholic
            • ak-
              • 12422
              The pressure. I can feel it.
              I'll see what I can do when I have access to my car.
              1991 325iS turbo
              • Garageaholic
                • Dec 2005
                • 5204
                Yes!!!!!!!!!!!!! Thanks!
                Recent Rebranding!!
                E30 SM62/S62
                E30 M60 V8
                E30 M30 Big 6!
                • bernzpeed
                  • 3917
                  yoh da man!
                  89 E30 S52
                  • azael325i
                    • Dec 2009
                    • 1258
                    I also have the skirts and haven't install them. Lol.
                    http://www.r3vlimited.com/board/show...46#post3229446
                    • White325is
                      • Oct 2006
                      • 5947
                      I also have the side skirts. I just used double sided tape and three screws on the bottom. zero issues and they wont ever go any place.
                      also for sale. :)
                      • bmwstephen
                        • 2463
                        Bernz,
                        Alternatively what you can do is secure the clips that are to clip against the rocker onto the skirts. Dab the POINTED TIPS of the clips with some paint and try to pre-fit/mount them on the rockers. It should leave a mark on which spots to drill. Thats how Ryan G did my skirts.
                        Be careful when drilling, behind the rockers are some electrical wiring that you don't want your drill bit to go through
                        -Blame my typos on my fat fingers & Droid Charge
                        • bmwstephen
                          • 2463
                          And wen u eff up. Fill with jb weld and redrill. Make sure that before you install plastic grommets that go into those holes (which in turn the clips' heads snap into), you coat the neck with some sort of sealant to prevent rust around the cavity area it's going to be inserted into
                          • nomansland92
                            • 1657
                            ^ very import, seal it very well to prevent rust. Maybe a good idea to repaint everything that will be cover to also help prevent rust if you don't plan on taking them back off
                            IX being restored here
                            Ix turbo build here
                            • Heyitzsushiboi
                              • 133
                              I too am interested in sideskirt help! Thanks!
