Installing euro rear plate filler.
This topic is closed.
  • BMW BMXER
    • 2325
    Sheesh how much does a job like that run you
    Sold it.
    • rwh11385
      lance_entities
      • 18403
      it's funny how I couldn't find this thread
      but i needed its help to install my new filler (euro beeotch! not US)
      mtechnik-3, thanks greg! :D
      • Rob
        • 8166
        my us plate filler is in the mail *shrug*, I like how it looks
        BEERTECH
        • lowslowe30
          • 204
          Does the us plate filler come in black? Is it for early model cars as well? and lastly where can one get a hold of this peice? Thanks
          • m42technic
            • 1056
            Anyone know how the euro plate fillers are attached from the factory? Im just curious...
            James Peacock
            WWFSMD?
            • kencopperwheat
              King of Kegstands
              • 14396
              Originally posted by BloodLine
              I paid to have mine installed :roll: I gave them instructions I got from Eric Lukas, and they installed it with everything else.
              Hi, my name is Jim. I gloat about money.
              Originally posted by Gruelius
              • Bryson
                • 1490
                dude, you have way too much money :roll:
                • lowslowe30
                  • 204
                  BloodLine wrote:
                  I paid to have mine installed I gave them instructions I got from Eric Lukas, and they installed it with everything else.
                  And also apparantly no technical know how whatsoever. Do you call someone to change your tire when you get a flat too?
                  • Digitalwave
                    is a poseur
                    • 6299
                    Thats gay as hell, I installed mine in 15 minutes.
                    James, have you seen one? They have 2 holes for screws on the top near the reverse lights.
                    I popped the plastic things that the plate mounts to off, then lined up the filler and drilled 2 holes on the top only.
                    Then I used flat-headed stainless steel hardware and lock nuts to secure it, looks pretty good.
                    RISING EDGE
                    • rwh11385
                      lance_entities
                      • 18403
                      Installs really clean TJ.
                      But just clarify what you did. The 'plastic things you popped off' are the white license plate mounts, right? And then you lined up the top screws and drilled through the plate. Or have I misunderstood?
                      Did you do anything will the hole near the reverse light, they don't seem to line up with anything.
                      thanks
                      • LikeCDoos
                        • Jan 2004
                        • 2522
                        I like how both look, but would probably get the US as well just becaue the plate would fits, whereas with the euro filler there are big gaps.
                          • 34847
                          here's a picture of mine:
                          I used the stock holes on the car to mount the plate, opting to drill through the filler peice rather than the car. I'm using screws with the little plastic nubs on the inside of the trunk, nuts and bolts on the inside would be a better choice but it hasn't fallen off yet so I'm not too worried. :)
                          edit: just for reference, here is a pic without:
                          it looks very empty and unfinished wihtout. :)
                          • m42technic
                            • 1056
                            Yes, Ive seen Eric Lukas's. Never really examined it very closely though. I just figured since you guys are having to drill holes and such, they must be secured differently on stock european cars... other than the plate attaching screws being in obviously different places.
                            James Peacock
                            WWFSMD?
                            • rwh11385
                              lance_entities
                              • 18403
                              Was doing it this afternoon, and had a digital camera with me......
                              Tools: Hammer, Sharpie, Drill, Washer, Bolts, Nuts
                              Hammer out those stupid white thingys......
                              Supplies.....forgot washers......ran to store quick to spend another $.66
                              Hold filler up to hole. Center and mark the holes' spots on the filler from the inside of the trunk....DRILL! :twisted:
                              I started with a small drill bit, then moved up, easier that way.
                              Put on drilled filler, put bolts through, tightened down nut ontop of washer.....simple
                              what kind of a slacker pays someone to do this?!?
                              I will paint my filler later, it is a lil faded. Same with spoiler, trim, and lower valence.
                              • Jb325is
                                • 2137
                                Get your car buffed or at least put some wax on that thing. Looks great though!
                                - '88 m54 coupe
                                <3
