No Tach
  • 82eye
    • Jan 2009
    • 2108
    Originally posted by Gtfour
    Yes but if I have the 318is original cluster, what is the other part that isn’t compatible with it?
    sounds like the tach has been replaced with a 6 cyl tach.
    edit : the tachs are electronic. they read off pulses when the cylinders fire. a 6 cyl tach registers one revolution every 6 pulses. if you have a four banger it will read slower as it only gets 6 pulses every revolution and a half on a 4 cyl. it'll register a third or so slower.
    • AWDBOB
      hooptie connoisseur
      • Aug 2013
      • 4511
      tachs are the SAME between 4 and 6 cyl cars. There's no 4cyl and 6cyl tach. The coding plug is different. He needs coding plug 1394321 for the 4cyl 7k cluster.
      If the entire cluster was swapped with a 6cyl cluster, the coding plug is likely incorrect for his car.
      The 318iS also has a single sender, smaller fuel tank, so the M20 late model 6cyl cluster fuel gauge won't read right if installed in a 318iS chassis.
      Late model 6cyl cluster = different coding plug and fuel gauge than Late model m42 cluster , otherwise the same.
      That means the same SI board, tach, speedo, casing, coolant temp gauge, main board, etc.
      • 82eye
        • Jan 2009
        • 2108
        are the coding plugs swappable between the two or are they physically different? if the plugs are different, not sure how it's able to plug it in or get any tach signal.
        the tach does work off a pulse. i've seen this happen on cars other than bmw between a 6 and 4 cyl.
        • AWDBOB
          hooptie connoisseur
          • Aug 2013
          • 4511
          Si board is the same between the two, as is the cluster housing, so the coding plugs are plug n' play
          • 82eye
            • Jan 2009
            • 2108
            so he's got a whole cluster from the 6 then ? i always thought the plugs were different between the 6 and 4 tach and would not swap. how does changing a plug fix anything if they are the same ?
            • 82eye
              • Jan 2009
              • 2108
              ok answered my own question .. the plugs are physically the same but there is a small processor and pcb board inside which changes between the different cars and clusters.
              • AWDBOB
                hooptie connoisseur
                • Aug 2013
                • 4511
                It’s impossible to say what cluster they have without more info
                the coding plug is the same physical size.
                different in the coding part, same in the plug part
                • 82eye
                  • Jan 2009
                  • 2108
                  yeah i just saw the difference is internal but the plugs are physically identical. i didn't expect a processor in the plug but it makes sense. cheaper for a company to change a plug between cars than build a whole different tach.
                  • Gtfour
                    • Apr 2023
                    • 63
                    Thanks a lot!
                    Everything else ‘’work’’ in my cluster, except mileage gears needs to be replaced, coolant temperature gauge works but heater valve needs to be replace, right side lights won’t work, …
                    I haven’t start working on this car yet but it needs a complete overhaul and still not sure which route I want to go with the engine…
                    2003.5 BMW E46 M3 Laguna Seca Blue/LSB 6mt
                    2006 BMW E46 M3 Individual Estoril Blue/Black 6mt
                    2024 Toyota Land Cruiser Black
                    • McGyver
                      • 4636
                      The biggest difference is earl/late clusters. Components can't be swapped between them, and I don't believe you can but an early cluster in a late car and vis-versa. I believe you can swap motometer into VDO clusters and vis-versa.
