My dash! My dash! O my God my dash!!!!
  • AndrewBird
    The Mad Scientist
    • 11898
    #31
    The reason a dash cracks is because the foam under the vinyl expands and contract differently than the vinyl. When the dashes are new, the vinyl is able to stretch and flex more, but as they get older, the vinyl becomes harder and instead of flexing, it cracks. This is why using a dash protectant that actually conditions the vinyl is important.
    Info on Armor All:
    Like the others said, go to safeway and grab a Visa Gift card. It's basically a prepaid debit card. Originally Posted by Coastalf350 I dont like it bu
    • joncrz
      • Jul 2013
      • 364
      #32
      Info on Armor All:
      http://www.autogeekonline.net/forum/...-question.html
      So on the forum the consensus is if you had the old formula armoall from the 70s and 80s it was bad but now its substandard but wont crack your dash... unless I am missing that it doesnt condition the vinyl?
      the other point I got was people recommending other products but no mention as to if it conditions the vinyl or not.
      insight?
      edit: I quick google search scares me, found a hotrod forum where a friend of a user uses tranny fluid to condition the dash... wtf
      My don't quote me list:
      I could be wrong, but I don't think it's a smog test type of thing. IIRC think it's against CA law to *sell* a dual outlet muffler as a replacement for a car that came from the factory with a single. But don't quote me on that.
      • AndrewBird
        The Mad Scientist
        • 11898
        #33
        Basically most guys don't like it because it leaves a slimy, high gloss finish that collects dust. There are better products for the same amount of money.
        • KIRIEIW
          • Dec 2012
          • 3385
          #34
          Originally posted by travis816
          were would you find those at?
          Do a quick google search. I know they have them on eBay but I would do a little research for the best brand. You almost can't tell you have one on when its on. I'm going to buy one soon
          1992 e34 Touring- S50 Swap
          1992 325i-S50 Swap (SOLD)
          1991
          • monty23psk
            • Mar 2008
            • 1289
            #35
            The new dashes from BMW are supposed to be a different material to prevent cracking like the new BMWs.
            Here is what I use for the 10+ years:
            Alex 88 m5 | 91 318is | 19 Subaru Ascent
            BMW Tool Rentals & Fender Roller
            • LoneWolf
              • 402
              #36
              Driving the other day, it was pretty cold. I hit a bump and heard this really loud crack. I thought a large rock had struck the window, and started looking for a chip. Didn't see anything.
              When I got to work though I saw what had happened. The dash split from the defrost vent and through the little storage tray. Amazing.
              • BMWManiac
                • Dec 2010
                • 1091
                #37
                Can anyone confirm the new dash? What about the center console and tray? If I were to order all 3 x new, are they all the same material now? Would like to finish my interior restoration!
                1997 Artic Silver M3
                CES GT4094r 651hp/615tq @ 24 psi
                • KIRIEIW
                  • Dec 2012
                  • 3385
                  #38
                  That sucks man, sorry to hear.
                  1991
                  • noE30
                    • Jun 2008
                    • 2260
                    #39
                    The ebrake console has a different finish than the original, I bought one about 2 years ago for my car. It's close enough but it's still noticable to someone who might care.
                    I believe that all the new dashes have the newer finish as well.
                    Flickr
                    @michael.colby on Instagram
                    "All he needed was a wheel in his hand and four on the road"
                    • jasonbk
                      • Aug 2011
                      • 555
                      #40
                      My e30 came with newer dashboard (I guess PO installed it), it's definitely softer and got much smoother surface texture.
                      • DesertBMW
                        • Aug 2011
                        • 1030
                        #41
                        I live in hot climate. I found out that using Vaseline then let is melt in the sun and let the dash soak, will reduce cracks and further drying of dashboard. If your dash just developed a crack it is too late, the material simply lost its oils do to evaporation. If you buy a brand new dash that was manufactured within few years and you keep oiling it, it will never crack. Problem is even if you find brand new dash at the dealer, it was probably made 20 years ago and it is too dry to save it anyway and will simply crack, but the cracks won't widen too much.
                        • MPLFoster
                          • May 2013
                          • 1490
                          #42
                          Originally posted by Steven
                          Armoral is badddddddddd..
                          x1,000
                          it's total shit.
                          form.follows.function IG @mplfoster
                          • woc
                            • 202
                            #43
                            Just got a new dash from the yard, $50.00 bucks took it out in 10 minutes, cause everything else was gone as far as climate control units steering wheel and cluster and shit. wel.. it has a 1/4 inch clack on the passenger side, you cant even see it because it's behind the downward molding. One thing I noticed about this dash thou, it looks very dry, and full of dust, so I cleaned with soap and water, now I want to moistorize it, maybe reconditioner shampoo? LOL IDK! anyone here have reconditioned a dash? best product, advices. Sorry OP, Im kinda in the same situation as you, and dude, get a dash from the yard, its cheap.
                            • woc
                              • 202
                              #44
                              also, found this. http://www.youtube.com/watch?v=yD1QqO5ZfAM
                              • OnMy2ndE30
                                • Sep 2011
                                • 385
                                #45
                                I found this while poking around for a fix for my dash: http://www.classiczcars.com/forums/i...-pictures.html
                                A buddy of mine gave me a old dash he had lying around and I decided to give it a try. I Will post pictures and results when I am finished with the dash. I am about halfway through with it and so far it is looking promising....
