Getting low beams to stay on???
  • parkerbink
    • Jun 2004
    • 10138
    As much as it pains me I have to agree with Jordan on this one.
    On my 90 which had sealed beams I connected the ellipsoid connector to the positive & negative terminals on the stock connector (after crimping a male connector I got at Radio Shack) to the wires thereby avoiding having to mess with the wiring and in order to allow me to return to stock should I need to. This worked for regular halogens and is now working with HIDs. I just removed the ellipsoid connector and connected the ballast.
    • Andy
      • Nov 2005
      • 121
      Originally posted by Jordan
      Just pair the 2 hot wires together to feed the HID +. One is + when low beams are on, other is switched + when high beams are on.
      Could you please describe in detail what you mean, I’m unsure which wires you’re talking about.
      I own an ’87 325is and last night removed the stock sealed beam headlight assembly and installed a set of euro ellipsoids. I want my low beams to stay on when I turn the high beams on. Thanks.
      - 1987 BMW 325is
      - 2002 BMW M3
      - 2003 BMW 540i Sport
      • PaulZ
        • Aug 2005
        • 118
        Can you explain your method in a little more detail, like explaining which wires need to where...I'm still a little confused on your description...
        On my high beams, I have the 2 white/blue wires tied together for the + terminal and the brown for the -
        On my low beams, I have the brown on the -, and one of the wires on the + can't remember which color, and the other tied off.
        Thanks!
        • Jordan
          • 12916
          Both + wires on the lowbeam must be tied together. All that need be done!
          https://mtechniqueabs.com/
          • asubimmer
            • 6482
            i have a 91' 318is w/ us ellips and when i put the 2 other wires on the lows together then the lows won't turn on and then when I hit the highs the low's fuses blow?!?!
            • PaulZ
              • Aug 2005
              • 118
              OK I'll give it a try...
              • PaulZ
                • Aug 2005
                • 118
                may be a difference between our cars (87's) and yours...
                • asubimmer
                  • 6482
                  anyone know how to make my lows stay on. My highs are REALLY bright as it is but the lows would help fill out the road some.
                  • rs4pro3
                    • 5808
                    Well first post what year car you have, and if you want a clean factory like mod, or just a hack job quicky.
                    85 325e 2.7 ITB'd stroker
                    • asubimmer
                      • 6482
                      the cleaner the better but right now I would just be happy w/ them working
                      • Jordan
                        • 12916
                        91 318iS is different then a 87. My mod only applies to early sealed beam cars.
                        • PaulZ
                          • Aug 2005
                          • 118
                          I tried your method last night and now both the low and high beam go on and off at the same time...what's up?
                          • Jordan
                            • 12916
                            You are doing something wrong then.
                            • PaulZ
                              • Aug 2005
                              • 118
                              Well obviously somethings wrong, but I did exactly what you said to do from your "experience" and it doesn't work. I connected the 2 + wires to the low beam. After thinking about this, it would only make sence that the high beam would go on, because by doing this I created a direct feed to the + terminal on the high beam when the low beam is on...
                              Anyone that could help me out with this?
                              • Jordan
                                • 12916
                                Sigh... beyond help, sorry.
