Harness Overload? High Beam + Low Beam
  • Powling
    • Jan 2015
    • 1290
    I came across an old thread that states you can just solder a wire between these two fuses in order to keep your low beams on when you turn your high beams on with euro smiley headlights.
    My question is whether this will overload the wiring anywhere?
    Steve • Toronto
    1991 318is • Brillantrot
    Build Thread
  • nrubenstein
    • 3148
    The answer is no - because you’re just triggering the relay if you’ve wired it correctly.
    Also, soldering is not necessary. If you stuff a wire in the sockets and press the relay in, that’ll work just fine.
    2002 BMW M3 Alpinweiß/Black
    1999 323i GTS2 Alpinweiß
    1995 M3 Dakargelb/Black
    - S50B32/S6S420G/3.91
    1990 325is Brilliantrot/Tan
    1989 M3 Alpinweiß/Black
    • Powling
      • Jan 2015
      • 1290
      Thanks! Wanted to make sure before I go and burn my car to the ground with an electrical fire ;)
      Steve • Toronto
      Build Thread
      • Northern
        I like cupcakes & sh!tboxes
        • 5248
        I can't remember for certain, but I swear there's a way to make the lows stay on with the highs by only modding one relay.
        Edit: This is more likely a memory from independent fogs actually.
        Originally posted by priapism
        Originally posted by shameson
          • 34844
          Mine has been like that for like 15 years. lol. it won't hurt anything.
          I just stuffed a wire in the sockets though, I didn't solder anything.
          • doctorx
            • Mar 2019
            • 65
            is there a howto on doing this? I am interested in doing this. ie.. which relays and blades do we do this? I thought i saw this in faq...but cannot remember which site. Ill try here again.
            • Zeemz
              • 485
              Good info and pics in these threads. I was getting ready to do this when I install my new lights and wire up the city lights as well.
              And independent fogs too.
              1989 325is Lachssilber - Sold
              1990 325is Sterlingsilber - Current Project
              September 2018 Car of the Month: Zeemz
              Youtube Track & Autocross Videos
