DDM Tuning HID Kits - Apexcone - $55 is that right?
"Life's Journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting...Holy S**t!! What a Ride!!" -
You may want to do some research on heat or melting issues. I'm not sure, but if Ellipsoid high beams have any plastic in them, a 55w could cause some problems there.Comment
I ordered the 55w apexcone kit but receved the DDM slim ballast. I plugged one in to see if it was a brighter unit as they claim a 40% increase in light output but they look the same. The website say the 55w ballast is larger. Does anyone have the slim kit dimensions so i can compare to see which ballast i have.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
www.gecoils.com
My euro 316 project Transaction FeedbackComment
Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.Comment
Mine measued in at 2.5"x3.5"x.75". So which kit do i have?Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
www.gecoils.com
55W halogen bulbs: Less light output with same power usage. This means that more of the energy is converted to heat.
55W HID bulbs: Higher light output with same power usage. This means that less of the energy is converted to heat.
In other words, HIDs run cooler.Comment
I'm going with 35w 5000k's.
Should be installed this coming weekend. I'll post pics.turk@gutenparts.com
Originally posted by JandersonProperly placed zip ties will hold bridges together.Comment
do they actually last, or do you have to use the warranty often? I deal with a company that dealer cost is considerably higher, but they said they have tried all the cheap ones, and they had a high failure rate, and I have installed some that had to be rewired, as they came wired backwards (most of the ebay ones) if these are decent I will use themComment
??? Where did you get yours from?? Mine were $63 shipped.turk@gutenparts.com
How long is the shipping?
Is this with a slim ballast?
whats the difference between 5000 and 6000?
I have the smoked laminix covering on my ellipsoids. which one would you suggest? I want something OEM look.
US elliposoid low beam is 9006 right?
Thanks.Comment
turk@gutenparts.com
