Miller Performance MMS 1.3ECU Better Then MS/MS2?????????
  • SamE30e
    • Sep 2007
    • 4319
    If it has 2 step rev limiter, i'm in.
    1985 325e 2.8 Turbo VEMS
    • ja burna
      • Jun 2005
      • 358
      Ok so who is going to be the guinea pig?? Thats the only way were all gonna know for sure.
      "Driving anything else would be uncivilised"
      • Sean
        • 5793
        Seems like an expensive test. Maybe you can just e-mail Miller?
        - Sean Hayes
        • SamE30e
          • Sep 2007
          • 4319
          I think I found one flaw..
          Does it eliminate the AFM?
          • SamE30e
            • Sep 2007
            • 4319
            I e-mailed them and asked if it does.
            You can make a 2 step revlimiter if you want, with the switchable maps you can just run a duplicate of your map with a different rev limit, just make the switch your clutch switch.
            • SamE30e
              • Sep 2007
              • 4319
              I got an e-mail back and you can't eliminate the air flow sensor, you can only convert to MAF from AFM.
                • 34844
                no, not unless you also buy a maf kit
                don't be fooled, this is just a SMT6 piggy back that's been built into the motronic case. it's fairly slick, but it comes with all the limitations of a piggy back computer and motronic.
                • SamE30e
                  • Sep 2007
                  • 4319
                  Thats weak!
                  I think I might go with a pre-built MS unit. I want a 2-step and no Air flow meter.
                    • 34844
                    the easiest way is to buy a pre built V3 board and the DIYautotune adapter - build the board, plug it into your harness and MS unit, and start tuning. :)
                    I wouldn't advise going with the v3.57 SMD board - although it is built very well, it's more difficult to modify and I don't think the extra cost is really justifiable.
                    • SamE30e
                      • Sep 2007
                      • 4319
                      Oh, I have no problem building the harness, its just all that stupid shit soldering to the board.
                      I'll buy the 12' labeled harness and a pre-built V3. As long as all I have to do is wire it into the car and tune i'm fine. If not I'm buying an Electromotive Tec-3R.
