The Cabrio Suspension Thread
This is a sticky topic.
  • reelizmpro
    • 9496
    #316
    The Koni's that came on my vert were not vert specific but 51mm Bilstein sports are designated for all E30's. That's another reason for the H&R Race/Bilstein swap from my M3 to the vert. Bilstein sports are stiff shocks but they control the springs well and last a long time. They are very stiff and not bouncy at all. It all comes down to personal preference though. Everyone has their own definition of stiff.
    88 M3 - LACHSSILBER/SCHWARZE
    • bryant.cw
      • 209
      #317
      I am running:
      Eibach pro kit
      Billie Sports
      M3 CABs
      No spring pads in front
      e92 drop hats
      1 Spring pad in the rear
      Race Skids front subframe brace
      Stock 14's with pretty small tires that are worn down. I think 16's with larger tires would look better/lower/less gap. Oil pan is as close to the ground as I would like as there are a few light scrapes on it now.
      Ride is stiffer but not super stiff. Dampening is very good with no bouncing at all. It does sway quite a bit in a sharp turn when on the gas, but very controllable, no bouncing or unsettled feeling to it. I still need to replace some bushings, and find it quite choppy/shaky in the front end over bumps in the road. I think I need upper strut bearings, a rebuilt steering rack, and new wheel bearings, in addition to all the bushings. It doesn't feel out of control at all, it just jars the front quite a bit. It is raked pretty well, and the back end never gets saggy.
      Best pic I have.
      ***Picture Gallery***
      • e30trooper
        • 11576
        #318
        Still waiting on that pic berry. I want some ideas...
        • reelizmpro
          • 9496
          #319
          Hard to see the rear tire thru the shadows but the reverse rake isn't as bad as it appears in the pics.
          • 89AlpineM3
            • 548
            #320
            Ok I have a 91' 325i vert and a 89 M3. I was planning picking up a set of stock M3 springs to run in the vert. The M3 is getting GC coilovers so I was wondering if I can run the EIBACH pro kit off the M3 on the vert?
            • IronmanE30
              • Sep 2009
              • 2121
              #321
              Eibach makes springs specific to the vert so if yours are for the coupe you may end up with reverse rake.
              Cheers,
              Jim
              • BergerNJ
                • Oct 2009
                • 349
                #322
                The reverse rake looks too noticeable for my taste..
                Now I'm really lost here lol
                • reelizmpro
                  • 9496
                  #323
                  Don't run Eibach pro kits for a sedan on a vert. That's what I had in mine. It was slammed and the pro kits were not stiff enough so I bottomed out a lot. To keep the rear high the PO used spring spacers in between the coils. H&R Race/IE3 springs give almost the same front/rear drop. While the other springs lower the front a lot more than the rear. So if the rake bothers you, go with the vert specific H&R's are Eibach's.
                  • CorvallisBMW
                    Long Schlong Longhammer
                    • 13039
                    #324
                    Seems like H&R Race or IE3 are a good idea for 'vert owners.
                    I've run the Eibach sedan/coupe springs before and while the front was fine, the rear was far too soft and sagged quite badly. I've also run the H&R Convertible-specific springs and was unhappy with them. They rode very high and very stiff, almost like H&R overcompensated for the extra weight.
                    As it sits now I have a combination of the 2: Eibach sedans springs in the front, H&R convertible-specific sports in the rear. All pads in, e90 drop hats and Bilstien Sports all around.
                    edit: just ordered GC 375/600 kit. Adjustability FTW. SO if anyone wants to buy my current setup, it will be for sale shortly.
                    • N2MYE30
                      • Oct 2007
                      • 5536
                      #325
                      ^^^ nice!!!
                      Here is mine updated from earlier in this thread.
                      Bilsteins sports all around
                      H&R sport coupe springs all around
                      All pads in
                      15mm drophats
                      COTM
                      • IronmanE30
                        • Sep 2009
                        • 2121
                        #326
                        That looks good. I am surprised that you did not end up with reverse rake with coupe springs but I guess the drop hats helped with that. Very clean car and my favorite color.:D
                        Cheers,
                        Jim
                        • reelizmpro
                          • 9496
                          #327
                          Yeah both cars have a nice stance. I'm sure the drop hats have a lot to do with it. This is why a lot of people cut a deadcoil off the fronts of H&R Race/IE3's. Looks perfect guys.
                          • mach schnell
                            • Apr 2008
                            • 1059
                            #328
                            What are some good springs that will get a 'vert nice and low? As in, lower than H&R Sport's?
                            Vogtland maybe? Any pics?
                            • mattdk318i
                              • Jun 2006
                              • 3953
                              #329
                              if you read through this thread its discussed many time. Thus a thread for nothing but cabrios
                              • mach schnell
                                • Apr 2008
                                • 1059
                                #330
                                Actually, it's not. There really is not a good clean low setup shown. There are plenty of hacked together combos (cabrio fronts, coupe rears, this and that).
                                I'm looking for a cabrio specific setup, not a combo of two different sets of springs, or springs intended for a non-cabrio E30. And I don't want Ground Control's.
