- Here is the easiest way that I've found to do this:
You would normally do this on the underside of the car, but I'm doing this outside the car so I can actually take pictures.
Harbor Freight item 96572 is what you will need. Now on sale!
This is the position you want to start the tool in. Place the handle directly on top of the shift carrier.
Close-up of the starting position. Place the tip of the pick in the corner of the groove. Pull the handle straight back from here.
This is the final position after you've pulled the pick straight back. It should unlatch the clip so you can undo the rest with your hand.
This is how it looks when you do it.
Booyah! :alright
Booyah! :alright
