DIY: Undo the bitch clip the easy way.
  • 2mAn
    Señior Mod
    • 21093
    #31
    I'm at this point. I've already removed the trans brace and also removed the nuts and bolts that attach to the driveshaft to allow the tranny to tilt and get some angle but the tranny isn't moving.
    Do I need to remove all 6 of the nuts and bolts on the giubo, or should I loosen the motor mounts?
    I'll be heading to Harbor Freight today to confirm if the tool is NLA, a new HF just opened by my house so it's not a huge waste of time to go
    Simon
    Current Cars:
    -1966 Blue Boat
    -1969 Red VW
    -1986 White BMW
    -2006 Green Thing
    Make R3V Great Again -2020
    • jeffnhiscars
      • Jun 2011
      • 6011
      #32
      i modified a curved HF pick and it worked perfectly. i'll try to upload a pic when they are done fixing my wifi. the key is to see it all exploded rather than working blind.
      fortunately i had a spare trans and shifter to fab the tool with some precision so took me a couple of minutes. that's after spending 3 days trying to install a new shift joint for my dssr without removing the bitch clip. lesson#4976...do not bother trying to install the shift joint pin from below
      Alice the Time Capsule
      • 2mAn
        Señior Mod
        • 21093
        #33
        Can confirm that HF no longer sells that tool but I went across the street to pep boys and they had it . $10 + tax and not much later the clip was ready to come out. Rather than fight repeatedly with it, I took my time making sure it was "hooked in" and off it came. Sliding it out was still a bitch but lesson #2 is that it's easier to use the right tools than to try fight with something similar that might work. Work smarter not harder
        Simon
        Current Cars:
        -1966 Blue Boat
        -1969 Red VW
        -1986 White BMW
        -2006 Green Thing
        • e30austin
          • 15382
          #34
          I have done this job with and without the tool. Definitely a "work smarter, not harder" situation without question.
          • rturbo 930
            • Dec 2005
            • 2629
            #35
            I replaced mine with a clevis pin. Problem solved.
            • e30austin
              • 15382
              #36
              I replaced mine with a M12 shoulder bolt and a lock nut. Problem solved.
              • Matt-B
                The Waffler
                • 3856
                #37
                I replaced mine with nail, just bent at both ends
                • mc625569
                  • Apr 2017
                  • 125
                  #38
                  No remove to remove B-Clip
                  I got the clip up w a screwdriver, but there wasn't enough clearance to lift the clip up all the way so that I could easily pop the pin out.
                  I had to loosen the bolts below the transmission mounts to allow enough room for me to get the clip up enough to get out. I just got this e30 and It looks like the transmission mounts are brand new.
                  Is it normal for the clip to hit the roof above it before angling up enough to allow for easy pin removal?
                  • kronus
                    • Apr 2008
                    • 13032
                    #39
                    yes, you typically need to drop the tail of the transmission a bit to get the clip out.
                    cars beep boop
                    • E30Bastard
                      Shimmy Shimmy Ya
                      • Nov 2018
                      • 245
                      #40
                      25111221849
                      Without the knowledge of "bitch clip" you'll end up searching the part number like an idiot and falling asleep under the car at 2AM.
                      "It wouldn't be there if it wasn't..." - Milton Berle
                      1988 325iS - M20
                      • 2mAn
                        Señior Mod
                        • 21093
                        #41
                        Originally posted by E30Bastard
                        25111221849
                        Welcome to the E30 lifestyle
                        Simon
                        Current Cars:
                        -1966 Blue Boat
                        -1969 Red VW
                        -1986 White BMW
                        -2006 Green Thing
                        • dmautz
                          • Feb 2019
                          • 4
                          #42
                          Apologies for bumping an ancient thread, but for anyone else who finds this thread and is looking for "the Harbor Freight tool" and is faced with broken links, it appears that the tool that was once sold by Harbor Freight, can be found by the name "JC PERFORMANCE PRODUCTS USA Radiator Hose Pick - Removal Tool for Stuck Radiator and Heating Hoses" on Amazon, and there are similar tools available that can be found under the term, "radiator hose pick". I can't yet speak for its effectiveness vs. a flat head screwdriver, but I've purchased one anyway to be prepared for an upcoming project.
