How to set MotoMeter odometer mileage
  • Cha Ching
    • 1668
    #31
    It's not a crime if you aren't defrauding someone. Jeeze...do you also not tear the tags off the mattress?
    I can tear those tags off legally?
    • straight6pwr
      • Sep 2004
      • 3450
      #32
      great write up. i currently have 3 mileage numbers to track (the odo, the actual chassis mileage, and the motor mileage) and this will make my life easier by knocking it down to two.
      • gmont02@yahoo.com
        • 53
        #33
        any idea to remove the glue from the batteries?
        '87 cabby parting
        sigpic92' calypso cabby preparing for storage
        • RagtopE30
          • Dec 2010
          • 1869
          #34
          No I havent messed with the SI board
          450whp 524 lb-ft 1988 336ic In progress
          http://www.r3vlimited.com/board/showthread.php?t=250709
          • Gubernaculum
            • Jun 2011
            • 69
            #35
            Back to the top - any update on VDO odometers? I just had mine apart for a gear replacement (brought to you by garagistic) and wish I had seen this thread earlier. Is the VDO procedure much different?
            • RagtopE30
              • Dec 2010
              • 1869
              #36
              VDO is much easier. I will put up a step by step tomorrow evening.
              • iwantspeed
                • 3164
                #37
                thank you
                Project
                Parts for Sale
                Feedback
                YouTube Channel
                • CaptDale
                  • Apr 2011
                  • 9
                  #38
                  Pretty awesome, thanks, this will help when I install my new cluster
                  • Dj Buttchug
                    • Jun 2010
                    • 7686
                    #39
                    just did this. reclocked to my 287 miles on brand new engine :) :) :)
                    Turbo M42 Build Thread :Here
                    Ig:ryno_pzk
                    I like the tuna here.
                    Originally posted by lambo
                    • mkcman17
                      • Jul 2010
                      • 8240
                      #40
                      that's a lot of work to just change the mileage. you don't really need to remove the face for vdo or moto.
                      1989 LN106 Hilux / 3.0TD SFA
                      1974 2002tii / stock
                      2002 IS300 / 5spd LSD
                      • Broom Broom
                        • Jul 2011
                        • 286
                        #41
                        damn...
                        i think i lost the tiny bearing from the motor,
                        i have a vdo and replaced the gears in it and it hasnt been working and should be, and i remember taking that motor out and not seeing a bearing, shit...
                        i need a new one...
                        only realised this is why my new gears are not working after reading this thread
                        - 1987 325e m20 6cyl manual -
                        • mccor023
                          • Jul 2011
                          • 683
                          #42
                          This is a great write up matt, thank you,
                          I was wondering if you knew where to order the plastic gears for the odo on the other side of the motor. I have 2 large gears that the teeth started to tear off, and the same for the very small black one.
                          Thanks
                          I love that people ask stupid questions so I dont have.
                          • jeffnhiscars
                            • Jun 2011
                            • 6011
                            #43
                            I replaced the VDO odo gears in 2 cars recently. On the 318i it had been broken for ages and as much as I wanted to bring the readings current, I did not want to risk taking it apart. On the 325 I was following the recommendation from odometergears.com by blowing out all the bits of debris with an air compressor. Turns out there is a paddlewheel (I cant recall which end of the gear shaft it was on) that when you hit it with air, it will wind the odometer back or forwards. This speedo hadnt been broken for long so I didnt change the readout, but I would guess that I could have wound it back to zero from 200k in 15 minutes with NO disassembly.
                            As for Federal Odometer Statements, cars over 10 years old check the "exempt" box. Case closed :-)
                            Alice the Time Capsule
                            • mkcman17
                              • Jul 2010
                              • 8240
                              #44
                              if any of you are too afraid of doing this, i have a couple dozen speedos leftover and can set em up and ship em out with new odogears.com gears for less than the cost of the gears themselves.
                              • rlddlr53
                                • Oct 2009
                                • 1450
                                #45
                                I had to fix the mileage on my current cluster, very easy to do, and dont have to take off needle/face as mkcman17 said
