How to Integrate RC Garage Opener in an E30
  • bernzpeed
    • 3917
    I initially started with this:
    But it won't work because the board is different.
    Get a remote-controlled garage opener like this one and open it up
    Then solder the wires on the board.
    Voila! No more fumbling for the garage door remote controller.
    89 E30 S52
    Transaction Feedback.
  • bradnic
    • Jul 2012
    • 3554
    pics don't work - please repost!
    HOWTOs:
    DB vert plastic bumpers
    OEM Keys
    MTech1 docs
    88 ix Lach/Card
    91 ic Calypso 3.1
    86 Cosmo 2.7
    OEM+ or bust!
    • bernzpeed
      • 3917
      Check this link out.
      89 E30 S52
      • kwill22
        • Apr 2009
        • 962
        What board did you use? Did you just program the 2nd rectangular opener and solder the wires to it?
        DENY IGNORANCE!
        Schwarz 325-totaled
        brilliantrot 318i-daily
        Originally posted by mkcman17
        don't think your hamster wheels are fast now. you will still have to give up when trying to pass that V6 odyssey to make your offramp.
        • E30_Pare
          • 7801
          Interesting.
          DREWLIENTE
          1$ PShops PM me
          • bernzpeed
            • 3917
            I used the board from the rectangular controller, yes. Soldered the external button from the top button. It was that simple.
            89 E30 S52
            • kwill22
              • Apr 2009
              • 962
              Simple, clean and effective. I will be doing this soon. From the looks of it you used a blank panel from the din area. Did you just put the board behind the din/console area
              DENY IGNORANCE!
              Schwarz 325-totaled
              • bradnic
                • Jul 2012
                • 3554
                Originally posted by bernzpeed
                Thanks!
                HOWTOs:
                OEM Keys
                MTech1 docs
                88 ix Lach/Card
                91 ic Calypso 3.1
                86 Cosmo 2.7
                OEM+ or bust!
                • dkmr
                  • Jan 2006
                  • 332
                  I like this. I just might do this to get the garage opener outa sight!
                  • DetailAddict
                    • Apr 2011
                    • 245
                    I did something similar to my Subar back then... But I removed the battery and tapped the cig lighter. This way, I never have to change out the battery and no one can open my garage door without turning on the car first.
                    Leo
                    • TrentW
                      • 2815
                      Coolio!
                      • einstein57
                        • Jun 2007
                        • 10780
                        I think i no what to do with the reverse fog light switch
                        www.gecoils.com
                        • bernzpeed
                          • 3917
                          Yes I did. Better if you put an insulation around it too.
                          Originally posted by bradnic
                          Thanks!
                          NP. :D
                          Get to work then! :D
                          Leo
                          Hmm, they aren't the same voltage though.
                          I initially thought of the fog lamp switch but I'm no electrical genius so I couldn't figure it out.
                          Originally posted by TrentW
                          Coolio!
                          :D
                          89 E30 S52
                          • DetailAddict
                            • Apr 2011
                            • 245
                            mine was 9v battery i think, but the 12v from cig was fine. It gave it much needed juice (mine was flaky on it's own).
                            Leo
                            • einstein57
                              • Jun 2007
                              • 10780
                              Same concept, just need to modify the switch so that it no longer locks in to place on the on position. You could also modify a window circuit breaker. But a window switch would work perfectly since its already a momentary switch. Get an early switch off a pre 85 e28 and remove the white paint with some acetone. Now you can use two of the buttons on your remote.
                              www.gecoils.com
