Upgrading to Parallel Flow Condenser
Are you asking why I'm using the stock bracket instead of the one it came with?Comment
Stop editing your post.
I should have it finished within the coming week or so. I haven't started yet. ;)Comment
what a write up! kinda wants a/c in my swap now... 50 degrees.. dayum.Originally posted by Lof84 doors allow you to transport more whores.
therefore, their value is much greater.Down to: 89 aw2 332i/4/5 , 70 Sahara 2002
1989 325i - 2.7i, Holset H1C, 60lb injectors, whodwho MS-PNP.
2012 Passat TDI - DD Duty
2008 GMC Yukon XL Denali - Kiddie hauler/grocery getterComment
Specs on how much freion, oil, and the pressures with your current setup. I don't want the AC guy to blow up my new system. :xComment
Alright I finally got my PF condensor in about 2 weeks ago. When I installed it, I also replaced the external rubber lines, new 2200 cfm aux fan, new o-rings all around, new dryer, new R-134 expansion valve, flushed the old oil in the entire system out, and put in a total of 6oz of PAG oil in their respected places. The setup works great. It was 98 the day I had the new setup vacuumed and recharged. It was nice and cool, even just sitting in the parking lot. I haven't had a chance to stick a thermo in the vents to see what it says, but I stay cool during the day and ice cold at night. The new setup took 1 lb 8oz of R-134. I believe it requires 2 more ounces if I recall right.
I'm in the process of making a DIY, so I'll post that soon for everyone.
I wanted to wait a little while before updating to make sure I didn't have any issues related to the new parts. So far none other than what seems like either a bad compressor clutch or maybe the compressor itself. Basically the coldest my AC gets is at 3k+ rpms. Doesn't matter if I'm sitting in a parking lot or blasting down the highway.Comment
