Upgrading to Parallel Flow Condenser
  • redsubdivisions
    • Feb 2011
    • 1762
    As many E30 owners can tell you, R-134 retrofitted systems in our cars aren't necessarily the most efficient systems due to our old, outdated and inefficient condensers. Yes, the tube and fin design sucks and if you're looking for something that is going to be a lot more efficient for your A/C system, then your lucky day has arrived: upgrading your E30's condenser.
    In order to get started on this, you will need the following:
    • A direct fit parallel flow condenser (I purchased mine from SupremeCondensers.com) - $88.00+ shipping
    • T-55 torx (for the two bolts that hold the bumper on)
    • 8mm socket (various ones all around the front fascia)
    • 10 mm socket (also used for the front fascia)
    • 13mm socket (also used for parts of the front fascia)
    • ratchet extension
    • 22mm wrench (for condenser)
    • 19mm wrench (for condenser)
    • assortment of O-rings (green; you will be replacing two o-rings, so don't go too crazy with this. Just a general retrofit kit one will do or you can go to your local parts/hardware store and match up 2 if you have time)
    • crescent (adjustable) wrench
    • razor blade (fan mounting grommets)
    • super glue (also for the fan mounting grommets; you'll see why)
    NOTE: Do this at your own discretion. This was done on a 1989 BMW US spec with an M20B25 in it.
    ANOTHER NOTE: Before doing this, I retrofitted just about everything on my E30. I changed out the following:
    • Compressor (reman; R-134 compatible)
    • Expansion valve (R-134 compatible)
    • Cleaned the evaporator (had a lot of gunk in it)
    • Dryer (fuck it, why not?)
    • Flushed out the lines with A/C flush (liquid type with compressed air)
    • O-rings where needed
    The only thing I didn't replace was the condenser and after MUCH research, I decided to go for a parallel flow condenser. I honestly had nothing to lose and I read many stories of people having success with this.
    Now, before you do anything or take any bolt off your car, VACUUM your system down and RECOVER all your refrigerant. You do not want to open up your system and have freon spray everywhere. It's not the best smelling substance and it's actually illegal to release it into the o-zone.
    Jack your car up on jack stands. This will make things a lot easier if your car is lowered (like mine). Pop the hood open, but don't open it all the way. Just leave it cracked. Now, remove your front grills:
    If you can't do this then you should stop altogether and consider paying someone else to do this for you.
    Once you have removed the grills, you can now see part of your old condenser and fan.
    There are two T-55 torx bolts that are located on the underside of the bumper. They are pretty apparent, so you can't miss them. You will need to remove these so you can slide the bumper off:
    If you pull on the bumper from the center a little bit at a time, you will notice it start to slide off. I would suggest getting a second person to help you with unplugging the lights. Remember, these cars are very old and brittle. If you don't take your time or aren't cautious, you will end up with this:
    This is where the super glue comes in handy. Once you've removed the entire bumper, apply some super glue and fix it now so it gives it time to sit and cure. Once you have removed the bumper out of the way, you will notice 8mm bolts that are holding on the front fascia. they are located in the following places:
    Headlight area
    Around the same area (there is a torx bit on the underside of this as well! I don't remember what size it is, but it much smaller. Around a T15 or that size):
    Front fenders near the bumper brackets:
    And there are the screws that hold on those bumper brackets. They are either 13mm or 10mm, so I suggest using a ratcheting wrench to get them off.
    Once these are all pulled off, you will want to unplug the fog lamps. Be careful because mine were very brittle and I thought they were going to disintegrate in my hand:
    Now the front fascia should come off. Be sure to take caution with the wiring harness that is attached to it. If it's not coming off, chances are you have forgotten something to take off and make sure you get all the necessary bolts off. Don't force it off, it will come off as one whole piece, otherwise you will bend it. Your car should look like this now (excuse the shitty phone pics; I was doing this solo in my garage):
    If you have an oil cooler, drop that down from the brackets holding it to the body. This will give you room to take the condenser out.
    You will need to use two wrenches of the same size or one 24mm/19mm and an adjustable wrench to take the hardlines off the condenser. using one wrench as support and the other to remove the hardline, be careful on taking them off. It may take a bit of budging, but it will come free. Be careful not to bend any of the lines. Once those are free, pop them off and at this point I would recommend replacing your o-rings. these are R12 seals and R134 gases will not work with them. Using a pick tool, pull them off, go to your local auto parts/hardware store and match them up and put them on the lines.
    Now, pop open your hood and look at your radiator. See these bolts? Yeah, remove them. You will need to in order to get to the brackets for the old condenser:
    now, pull that out of the way and remove the two bolts that are holding the condenser brackets to the body:
    Now, remove the cooling fan. If you would like to upgrade to a better/bigger fan, I suggest doing it now. It will make things easier and you won't have to do this job twice. you can remove the fan via three 8mm nuts that are attached to the mounting grommets.
    It should be fairly easy to remove the condenser at this point, and if you have successfully done so, you should have a nice free area for the new one to go in:
    Now, before you install the new condenser, pull off the fan mounting grommets from the old one and slice them in half. The reason why you need to do this is because there is no way to put them on the new one without cutting them or trying to jam them in:
    Now, put some super glue on them and attach the respective grommet pieces back together on the new fan bracket. If you did a decent job, this will hold pretty well.
    Going back to the front of the car, you can install your condenser:
    My condenser only came with one bracket. It was total bullshit, but at this point, I was tired and didn't care. I ziptied the bracket through the original mounting hole and it works for me. If you are die hard OCD about this, you can drill out the pop rivets on the new condenser, fab your own condenser bracket based on the old ones, and go onto the next step.
    You can mount your fan in now using the same bolts and hardware from your old condenser fan bracket:
    Re-installation is pretty straightforward. But make sure your wiring harness is connected to the fascia before you put everything back together and bolt everything down. Mine wasn't and was hitting my fan and now I have an ugly zip tie in the front of my car to hold it until I become un-lazy and fix it.
    Make sure you give your A/C system a nice deep vacuum. this will vaporize any moisture that has entered your system since you have opened it. I did mine for a good 45 minutes to make sure. I didn't replace my dryer after this because it was fairly new. It is a relatively cheap part, so if you feel the need to replace it, go for it.
    Once that's all done and said, go take it out for a spin. I noticed an immediate change compared to my last drive. I couldn't get my car any colder than 58F and that was at night time. With the new condenser, I was able to hit 53F in 95F ambient temperature (possibly even hotter out):
    1989 325i - 2.7i, Holset H1C, 60lb injectors, whodwho MS-PNP.
    2012 Passat TDI - DD Duty
    2008 GMC Yukon XL Denali - Kiddie hauler/grocery getter
  • FredK
    • 14763
    Nice writeup! This makes me want to reinstall my AC!
    • AbsorbantNut
      Non faccio funzionare questa merda
      • Jun 2010
      • 2491
      Nice! I'm going to have to put this on my to do list
      '73 2002 m20 turbo [sold] '87 rat rod 325is [couch modded] '91 vert [daily] '88 325is [spec build v1] '84 325 [spec build v2] '99 323i vert [sold]
      • nrubenstein
        • 3148
        If that's all you're getting, that's a complete waste of time. Using recirc, I can get 36 degrees out of the stock condenser. 42 degrees at idle. Fan speed 4. Ambient temps were 96-97.
        (sadly, it sprang a leak and I made the mistake of putting the serpentine Vista-Pro. Useless piece of junk that'll be coming out ASAP. It's literally 30+ degrees worse than stock in 90 degree weather.)
        Also, why didn't you just pull your radiator? Sure, it's a little awkward to get to the connectors, but it's entirely doable. Seems easier than taking apart the entire front end.
        2002 BMW M3 Alpinweiß/Black
        1999 323i GTS2 Alpinweiß
        1995 M3 Dakargelb/Black
        - S50B32/S6S420G/3.91
        1990 325is Brilliantrot/Tan
        1989 M3 Alpinweiß/Black
        • e30 gangsta
          • 3877
          What size aux fan is that? And where did you purchase it?
          • immajackuup
            • Dec 2010
            • 1132
            Think there is something wrong with op a/c system.
            • nrubenstein
              • 3148
              If recirc is off, probably not. What this tells me is that the drop in pf condensers really aren't offering much at all over stock - probably because they are built to perform similarly to stock. It's pretty clear that Matt's custom solution is still really the only one if you're after a dramatic improvement in performance.
              • LJ851
                • 7919
                ^nrub, don't you have an E36 compressor in your system? Also, what is Matt's custom solution?
                Lorin
                The M30 is God's engine.
                • frankenbeemer
                  • Sep 2009
                  • 2260
                  I don't see any proof of improvement in those temperatures. Do you have any wet bulb data?
                  Don't buy an e30
                  They're stupid
                  1989 325is Raged on then sold.
                  1988 325 SETA 2DR Beaten to death, then parted.
                  1988 325 SETA 4DR Parted.
                  1990 325i Cabrio Daily'd, then stored 2 yrs ago.
                  • redsubdivisions
                    • Feb 2011
                    • 1762
                    I pulled the front end so I didn't make a huge mess and have to rebleed my cooling system. Yes, it it possible to do it by taking the radiator out, but this is another alternative. As far is being a waste of time, to each his own. I went from only getting 58F at night time with recirculation on to in the early 40's at night. that temperature is a nice reduction from the stock setup and this is really meant for everyone that has R-134 conversion.
                    And why would you put in a serpentine in? That's similar to the tube and fin design. I just went straight for the parallel flow design because it dissipates heat a LOT more than a T&F/Serpentine would.
                    • redsubdivisions
                      • Feb 2011
                      • 1762
                      I purchased it on eBay after my stock one took a shit.
                      • redsubdivisions
                        • Feb 2011
                        • 1762
                        Also, for the record, I did not give my car enough time to get the air even colder when I did this. I was on my lunch break at work when I took the picture with the vent temp. 1PM in SW Florida in the middle of August is pretty hot. I honestly forgot to emphasize a few things in this, but I also wrote this up as soon as I got home from work. I wanted to take more pictures, but doing this job by myself was time consuming with taking pictures and making sure I didn't break shit or do anything incorrectly on my car.
                        • nrubenstein
                          • 3148
                          K's iX is 2 degrees worse with R134a. Not a big difference. Idle isn't as good, but that is because her aux fan doesn't have the resistor bypassed.
                          • ethrtyiS
                            • 8147
                            will be doing this as i hate how the performance goes down at idle.
                            thanks!
                            「'89 BMW 325is | '02 Mitsubishi Montero Limited | '2005 GMC Sierra 2500 Duramax | 2007 BMW M5 」
                            「my feedback thread」
                            • bimmershark
                              • 319
                              a/c is for waffleswaffleswaffleswaffleswaffless......true story
