Upgrading to Parallel Flow Condenser
  • redsubdivisions
    • Feb 2011
    • 1762
    #91
    Originally posted by rcfanatic
    americancondenser.com tells me they can only sell to businesses. They suggested usautoparts.net and ac-condensers.com. Did you use either of those?
    Tell them you're in the business of beating ass and taking names.
    1989 325i - 2.7i, Holset H1C, 60lb injectors, whodwho MS-PNP.
    2012 Passat TDI - DD Duty
    2008 GMC Yukon XL Denali - Kiddie hauler/grocery getter
    • glucklich21
      • 1912
      #92
      • rcfanatic
        • 490
        #93
        Originally posted by glucklich21
        My 14" curved fan pushes out 2400 CFMs and the coldest I saw was 38 degrees @ 85 on the highway (M42 @4k). 44-54 was my normal unless idling then it would hit 58 because I had an old compressor.
        What is the manufacturer and part# of this fan?
        • glucklich21
          • 1912
          #94
          Dunno, but this is the one I had on my new and old E30. It sounds like a jet is taking off on high speed.
          http://cgi.ebay.com/ws/eBayISAPI.dll...#ht_569wt_1027
          • glucklich21
            • 1912
            #95
            Made this tonight.
            • redsubdivisions
              • Feb 2011
              • 1762
              #96
              Glad to see you posted it on E30tech. I have yet to get my account approved on there otherwise this would have been cross posted. Some are skeptical about this but mine still works excellent to this day. I always feel better when contributions are effective to others. :up:
              • immajackuup
                • Dec 2010
                • 1132
                #97
                can't wait to get my 2400 cfm 16inch fan.:p
                • glucklich21
                  • 1912
                  #98
                  Dis^^
                  And you're just being crazy at this point.
                  I posted up the DIY here, but I'll have to wait for a mod to approve it.
                  • immajackuup
                    • Dec 2010
                    • 1132
                    #99
                    awww shitz,is gonna sound like jet taking off.
                    • glucklich21
                      • 1912
                      #100
                      Now on R3V
                      • rcfanatic
                        • 490
                        #101
                        got my a/c temp down to 42-45 driving/idle degree today!! got rid of 16spal pusher fan on condenser and use oem e36 radiator electric fan.
                        my previous set was only 16inch spal pusher fan on condenser getting 50-55 degree driving/idle.
                        I don't see how the e36 fan could blow that much more air than a spal 16". So did the 2400 cfm fan work better than the e36 fan?
                        • E30_Pare
                          • 7801
                          #102
                          I must be a waffleswaffleswaffleswaffleswaffles cause I don't like being grilled like a panini by my sick ass leather seats ***.
                          DREWLIENTE
                          1$ PShops PM me
                          • bmwstephen
                            • 2463
                            #103
                            what was the ambient temperature? and would you say it stayed 42-45 pretty consistent regardless of the current ambient temperature (ie +/-10 degrees?)
                            • bmwstephen
                              • 2463
                              #104
                              man after driving around the peninsula, north, east, and south bay to test out my AC system, I noticed the biggest factor affecting the efficiency of a system is humidity. Could not believe that a dry city like Sacramento would yield better results as much as 10 degrees than places closer to water like Fremont/San Jose under the same temperatures.
                              • glucklich21
                                • 1912
                                #105
                                Yup the E30 system just can't handle it. It honestly needs a larger condenser to get past it.
